Sau Vic 2012 Motorsport Championship Round 5 - Sandown 11Th August
emts
 Share
sounds like tampered, if you can can get into scruit under it's own power and not drop a couple litres of fluid, plus your helmet has a sticker you pass
  • Replies 307
Posted Images
Haha really? I heard some people at PI had cable tied their fire extinguisher in aswell
Me too, weight saving ftw. lol.
That is true :P
I've turn the boost down on my stock turbo to 9-10psi. So down to about 170-180rwkw.
So i'll be slowly going around the track whilst you zoom past me :P
Jam the GPS between the sun visor and roof. Phone goes in centre concole with helmet bag so it doesnt rattle around.
Camera mounts are somewhat of a farse. suction mounting is hit and miss with the officials.
So do we have a little area were we can put our tool kit, spare oil/coolant etc... that I want to bring just in case?
Do I just make sure I take it all out before it goes into scrutineering?
shove it in my car if you want. ill be driving there.
good to see more than 2 cars in the std awd class. hoping for a dry day though.
Fingers crossed. Would really like my first track day to be a dry one...
Weather at this stage doesn't appear to promising
hello to all,
introducing myself as a first time track day member. Looking forward to sandown this weekend. see you there!
Welcome!
I recall seeing your membership application come through :D
yeah weather not looking the best I have seen, but should make it more ....fun
oh well just so long as one dry session that enough.
oh for those of you that looking for a garage they can be pre-booked
ring Brendan on 0403189352 and give him the details of the day.
if you can get 3 of you together works well, as most are 3 bays so you can share with friends and put all your stuff under shelter.
when we were there earlier this year was $40 per garage.
I've booked 3 for me and my work mates.
Call today and ask to have one near mine if you want!
I'm interested Tony, and so is Artz i'm sure... You want to call or should I? :)
Yeah why not. $40 for 3 cars. $13.33 isn't going to break the bank
That way if my car breaks down you can help me fix it :D
You can call :)
Guest
 Share
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
