Sau Vic 2012 Motorsport Championship Round 5 - Sandown 11Th August
made from a piece of aluminium I found in the scrap bin at a truck place.. :)
took 20 mins to make and its like 6mm thick too, so not going anywhere but meant I needed longer bolts...
Mine is the same, though 3.5mm from bunnings.
  • Replies 307
Posted Images
I'm actually surprised they OK'ed that without washers under the bolt head.
I'm just tossing up whether I should buy the 48's Traction have on special or just run the KU36's again, there might be another day left in them, I hope...
Mine are the same, Stainless M6 cap screws with nylock nuts, no washers on 3mm alloy strap. The scrutineers were wrapped with the install, compared to some of the other ones they had seen last Saturday.
Oh Martin, I knew someone would complain..where would you like to see washers mate, I'll put some there for you ok..I'd love to lend you entry fee too mate but I had to beg and plead with the finance dept myself.. I find the trick is to ask just before they're about to climax as they will enthusiasticaly say yes to anything ;)..Bar that Just sell a kidney or something you know it's worth it.
if my tax arrives might even enter!
I have a feeling you'll be receiving it soon :P
Care to post a pic of what your awesome one looks like? :D
Just filled out my Cams licence just then and was about to send, but then just realised I don't have a passport photo. Cot dayum...
Just used a facebook picture for the photo. Cams processed and should get it next week :D
Edited by blah_blah
I only fitted them on the drivers side for now, mainly because I don't sit in the passenger seat often. I tried out the bitch seat today and it definitely needs spacing up 10 or so mm at the front.
When I did mine the cams regs asked for body washers both sides and 2 x M6 bolts.
that said just glanced at the current regs and they have removed mounting info other that it must withstand 25G..no idea how scrutineers can test that!
So I withdraw my comment looks like it would pass current regs
There are no washer for the seat.....
1. You don't want the fire ext under the brake pedal!
Man there's no way that extinguisher is getting past my legs, even if it did its not going to fit under the pedal..
It can easily be mo ed to the passenger side anyway should officials complain :)
If it's flying around the cabinet at PI it could end up anywhere.
End of the day, it's common sense. No teck screws, bolts that are made from metal and not plastic (zipties) and attached in two locations so it doesn't swivel all over the place.
Guest
    • Hey everyone!!  I've noticed that whenever I do my oil changes, after putting 4L in, the oil level sits at the top mark in the dipstick. This is after letting the old oil drain for a very long time too! I've checked the oil level daily for the past few mornings. It happens every time and it's confusing because all the threads say that it should take about 4.7L (With some just adding the full 5L) My next thought is to figure out if the dipstick I have is correct so could someone please tell me the length of the RB25DET engine oil dipstick?  I've checked images of some of the genuine dipsticks, but none of them have the length in it. https://justjap.com/products/genuine-nissan-engine-oil-level-dipstick-fits-nissan-r34-skyline-c34-stagea-c35-laurel-y34-cedric-gloria-rb25de-t-neo?currency=AUD&srsltid=AfmBOortQXofgmiHVRKuIaiKuygL4k0Ewp68c3isGZk0vvKOJ7Yqf3iB However.... the engraving on the genuine ones say 05002 while mine says AA000. This makes me believe that maybe I have a wrong dipstick? I just want to confirm before I buy a new one. The car is a fresh import from Japan so I don't have details of the previous owner to ask him. Thanks in advance 🙏🏾
    • Sport. I didn’t rebleed it cause I just removed the slave and left connected.    I will change line and slave and see how it goes.
    • Oh and how is the rattle when foot is on the clutch ?
    • Did you get the sport or track ? From what the documentation says the uniclutch has a small amount of movement to disengage.  So your story of tricky pedal setup seems common.    Hopefully you got it bled up too, as the bite point moving around is usually either plates wearing in or air in the line.
    • There's always "MIG it up and grind it back".
