Sau Vic 2012 Motorsport Championship Round 5 - Sandown 11Th August
lol it such a hack track compared to PI..
This is the bit I hear all about gets me worried...watch from 1 minute
that's Roy a SAU member.
he was leaking Gearbox oil I belive (could be engine)
so the rears were coated with oil when he went to turn in.
so assuming your not planning on pouring oil on tyres prior to going out you should be fine.
  • Replies 307
Posted Images
I went off turn one forgetting to brake lol
looks like i wont be partikipating here :( way too much needs to be done to get it on the track
allignment
touch up tune
tow
cams
membership renewal(will happen anyway)
but i doubt all will be done before the 11th lol
Edited by Sunkist
Scared bud?
Just get it all done, you will need it for the next track day. Why else are you powering the car up, you can't use it on the street...
Scared bud?
i am getting it all done. but traction tyres cant have me in till next week because i need to flare the guards some more.. and thats only if i have time then.
all happening. not as soon as i thought it would though.
Can we sign up for cams on the day or has to be done before hand...don't think there would be enough time for it to be processed by mail.
There is a tear off slip down the bottom of the application which you can use on the day.
An SAU VIC representative will have to sign it. As Richo won't be there I'm assuming Martin or myself can sign it?
Good to see another first timer will be out with me! :D
Or even an email. I sent mine in with an attached Facebook picture as the photo as I didn't have anything else lol
Was processed and sent out within a few hours :thumbsup:
Guest
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
