hi guys,
i think my o2 sensor is dead. my fuel economy sucks (250k's ish on a full tank) and my apexi pen timer doesn't read the o2 sensor value at all. my fuel economy has always been like this so i thought it was normal but reading some threads and doing some searching and it appears my o2 sensor is dead. i wasnt sure if the apexi pen timer was working properly cos it has never read the o2 value always displays "---" but ive checked the wring and it seems fine.
also when i had a dyno run on the dyno bbq day i got 141rwkw and it was running very rich and had some black smoke puff out
does anyone know where to get a new / 2nd hand o2 sensor from? how much?
any help would be great, thanks
Yea you can buy new ones for like ummmm around 150 i think but dont quote me! You can get second hand ones easily from workshops around the place usually like 80 or so not that expensive just make sure its ok before you buy it!
dunno but the 33 ones have 3 wires, im looking at my old one right now, I got a second hand one for like $80 from a workshop up here i know...check around you'll find one easy, they have heaps of them lying around!
nah its cool, ive already got a new o2 sensor just a bitch to fit and ive got really shit tools here. will organise with a mechanic to fit it for me and swap for a new radiator
hi all, have gotten the o2 sensor fitted and done. the ford el one did it fine. the apexi timer now shows the o2 value and it fluctates from 0.30 to 0.20 and 0.10 is this correct? upon de-acceration it goes to 0.02 and 0.01. however if i goto a/f it shows "---" still. am i missing something?
will update when i check my fuel consumption
the light for o2 goes from green to orange to red mainly at green when idle and orange when midrange accel and occasionally a spot of red if i stick it. ive only seen the highest about 0.40 shouldn't it be up near 0.60 ? the range as far as i know was 1.00 to 0.00 correct?
0.50 would be midrrange?
as in not lean and not rich
    • Ok, can confirm.  if you use it like a normal human being in the real world, it works fine.  it only starts crossing wires if I keep using the fob over and over again in a very short period. So if I just chill the f**k out, it works 😂😂
    • Im about to run a e30 mix of e85 and 98ron but i read that australian fuels specifically 98ron doesnt contain ethanol so on the calculator when it says pump ethanol percentage do i just put 0 or is this statement even true? And if it is true i assume i dont need to test any 98ron pumps.
    • So... the fob I had for my Skyline always had this issue where the "Unlock" button worked with no issues but the "Lock" button did nothing (and I always had to lock with the key) I thought I'd try resetting and pairing the key to the car today to see if that fixes the issue. I did the standard steps to program a key but realised my central locking was doing its own thing from time to time. 1st time: The driver-side doors would not lock or unlock when using the fob. No issues with the key. I figured it was the right time to change the battery in the fob so decided to go get one. When I went to the shop all doors locked and unlocked with the fob (while it had the old battery 🙃)   2nd time: When I locked the car, it would lock itself and immediately unlock. If I unlocked it, it would unlock and immediately lock.   3rd time:  After a bit of cursing and praying, that weird bug stopped. But then the rear passenger door started being a pain. It wouldn't really follow what the fob was asking it to do. Sometimes even using the key would not do what I wanted. So I'd lock the car with the key and all doors would lock, but the rear passenger lock didn't do anything at all. And then after a few moments, it would work again.   Is there a fuse that I should be looking at? or, is this one of those things where the door card needs to come off and some unit needs to be replaced? It just seems to happen from time to time and if I give her some space and come back later, there are no issues  🤦‍♂️ Also, should I try to program the fob again to the car just to see if that solves it?
    • One would assume a turbo is somewhere in its future down the line given they slap turbos on pretty much everything that arrives
    • I’m guess it’ll end up with a turbo
