Cheapest R33 Ecu Basic Dyno Tune Drive In Drive Away Only $600 Full Road Tune Dyno Tune From$700 Include Parts
R33 ecu $600 basic dyno tune is std AFM , std turbo , std injector only.
You need bigger fuel pump and boost controller.
This price includes everything to drive in drive away.
R33 ECU is exchange.
Road tune and dyno tune both $700 std AFM , std turbo , std injector.
If you will install bigger turbo and Z32 AFM I recommend dyno tune and road tune both.
How to tune R33 ECU
Real time Dyno or road or both tune by R33 ECU with R33 daughter board (made in Japan) , emulator and nistune software.
exactly same this.
http://www.nistune.c...e-emulation.php
http://nistune.com/d...or_Tutorial.pdf
Tuned data burn to chip.
Remove std R33 chip then Socket install to R33 ecu.
Tuned data chip install to socket
Dyno shop is at north Dee why NSW
Dyno is mainline dyno
Power is around 200kw at 12-13psi
Please check road tune and dyno tune
http://www.skylinesa...page__hl__toshi
Toshi
Ph 0410490049
e-mail [email protected]
Nistune Powerfc Fcon Remap Real Time Road Tune And Dyno Tune Available In Sydney.sending To Other State And Over Seas Also Abailable Now!
http://www.skylinesa...-abailable-now/
RB25DET boost limiter (R&R) is in timing map.
Full boost (96) column after 4400rpm , timing is only 5 5 8 5 3 8.
This is boost limiter (R&R).
If you want to boost up , ecu have to remap.
You will get 20-30kw more than std boost and std ecu by boost up and remap.
Z32 ecu and nistune board dyno tune and road tune both from $1150-1200 include Z32 ecu.(price is depends on Z32 ecu price)
R33 series 1.5 and 2 stock turbo is ceramic exhaust/ plastic compressor.
​Series 1 is ceramic exhaust/ metal compressor.
So I recommend series 1.5 and 2 boost up to 12-13psi.
Series 1 is 14psi not problem if turbo is good condition.
R34 early model is also ceramic exhaust/ plastic compressor.
I tuned Mr David Stankowski nissan laurel RB25 DET race car last year and he is driving REPCO PRO DRIFT CHAMPIONSHIP this year.
ECU is R33 ecu. (same this thread)
His car mods is FMIC , bigger fuel pump , my tuned ecu , and stock turbo!
Boost 15psi.
Yes, some times blow up turbo.
http://www.nissansil...1
Many people ask about bigger turbo tune.
Yes, R33 ecu is able to tune any mods.
This is R33 ecu tune
R33 S2
Unopened RB25 ~100,000km
Hypergear PU Highflow (non SS1)
Blitz return flow FMIC
Splitfire Coils
Metal intake with std airbox
Z32 AFM
S15 480cc injectors
Gizzmo Boost controller
Xtreme Cushion button clutch
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
