Cheapest R33 Ecu Basic Dyno Tune Drive In Drive Away Only $600 Full Road Tune Dyno Tune From$700 Include Parts
R33 ecu $600 basic dyno tune is std AFM , std turbo , std injector only.
You need bigger fuel pump and boost controller.
This price includes everything to drive in drive away.
R33 ECU is exchange.
Road tune and dyno tune both $700 std AFM , std turbo , std injector.
If you will install bigger turbo and Z32 AFM I recommend dyno tune and road tune both.
How to tune R33 ECU
Real time Dyno or road or both tune by R33 ECU with R33 daughter board (made in Japan) , emulator and nistune software.
exactly same this.
http://www.nistune.c...e-emulation.php
http://nistune.com/d...or_Tutorial.pdf
Tuned data burn to chip.
Remove std R33 chip then Socket install to R33 ecu.
Tuned data chip install to socket
Dyno shop is at north Dee why NSW
Dyno is mainline dyno
Power is around 200kw at 12-13psi
Please check road tune and dyno tune
http://www.skylinesa...page__hl__toshi
Toshi
Ph 0410490049
e-mail [email protected]
Nistune Powerfc Fcon Remap Real Time Road Tune And Dyno Tune Available In Sydney.sending To Other State And Over Seas Also Abailable Now!
http://www.skylinesa...-abailable-now/
RB25DET boost limiter (R&R) is in timing map.
Full boost (96) column after 4400rpm , timing is only 5 5 8 5 3 8.
This is boost limiter (R&R).
If you want to boost up , ecu have to remap.
You will get 20-30kw more than std boost and std ecu by boost up and remap.
Z32 ecu and nistune board dyno tune and road tune both from $1150-1200 include Z32 ecu.(price is depends on Z32 ecu price)
R33 series 1.5 and 2 stock turbo is ceramic exhaust/ plastic compressor.
​Series 1 is ceramic exhaust/ metal compressor.
So I recommend series 1.5 and 2 boost up to 12-13psi.
Series 1 is 14psi not problem if turbo is good condition.
R34 early model is also ceramic exhaust/ plastic compressor.
I tuned Mr David Stankowski nissan laurel RB25 DET race car last year and he is driving REPCO PRO DRIFT CHAMPIONSHIP this year.
ECU is R33 ecu. (same this thread)
His car mods is FMIC , bigger fuel pump , my tuned ecu , and stock turbo!
Boost 15psi.
Yes, some times blow up turbo.
http://www.nissansil...1
Many people ask about bigger turbo tune.
Yes, R33 ecu is able to tune any mods.
This is R33 ecu tune
R33 S2
Unopened RB25 ~100,000km
Hypergear PU Highflow (non SS1)
Blitz return flow FMIC
Splitfire Coils
Metal intake with std airbox
Z32 AFM
S15 480cc injectors
Gizzmo Boost controller
Xtreme Cushion button clutch
    • Yes. It's either "2 wires", or 1 wire, depending on how you look at it. It is the connection that ties the battery -ve to both the chassis and the engine. Every electron that goes in or out of the battery goes through those 2 small spots (on the inner guard and on the engine block). If those are not clean and tight, then shit starts to suffer. Yeah, but measure it again cold in the morning, after it has had hours to rest. You can't usefully test the charge state of a battery immediately after it has been running because the alternator puts a surface charge onto the plates that takes a while to soak in and balance out. It will always read higher, and potentially look properly healthy, when fresh off of charge. But hours later it can look a lot less healthy. It's also worth measuring the battery voltage while cranking, although this can be difficult with a typical DMM because the screem update rate is so slow on most of them. An analogue voltmeter is actually a better tool for that. If the voltage drops too far while cranking, it is a sign of a poor battery. Although I don't think we're necessarily looking for a weak battery here - just wanting to exclude it.
    • https://www.facebook.com/share/15ZMn5oXtc/ Updated Event (so its not private and can be shared easier)  Attempting to coordinate a big push of Stagea's to this years GTR Festival. Great event last year and hoping for the same this year.  Discounted tickets 20% off for their various tickets until the 3rd of Feb Monday. Drags, show and shine etc.  I've emailed them to ask to set a location aside for the Stageas for the show and shine - they are happy to do so if we can get them numbers, I'm happy to keep track of that. Entering as Nismo category.  I'll be road tripping up from Melbourne, would be cool to convey if people are interested, maybe there is SAU convoys from each capital? If you have ideas about that let me know.  https://gtrfestival.com.au
    • Does have series 2 airbag steering wheel and passenger side airbag also.
    • Do I have a series 2 or has someone spent money to have a series 1/1.5 look like a series 2? Everything I have read says the series 2 came out in 1996. I have a car manufactured in December 1995. The exterior, engine and interior are all series 2 other than the dash facia is series 1. Paint code is also kr4 that I believe is only available on a series 2. I have a VX Vehicle History Report and it says Grade: GTS25T TYPE M2 Manufacture date: 1995-12 Make: NISSAN Model: SKYLINE Body: E-ECR33 Grade: GTS25T TYPE M2 Engine: RB25DET Drive: 2WD Transmission: F5
    • I went to Repco to get them to test the battery using their tester (not a volt meter), alternator shows 14.3v when running, and when the car was off after the it was on full load I think it was 12.6v but the guy said it was all good. Terminals are all clean, no corrosion. Though I coulda sworn when I tightened up my alternator belt the car idles a bit higher and the steering wheel shakes a bit until it's warmed up. I wanted to confirm for the earth cable/s, are you referring to the 2 wires that are bolted onto the frame rail under the battery? I might be overthinking this a bit.
