I'm currently trying to figure out what would be best suited out of these two sizes but I don't really have my head around offsets too well.
I want the wheels to be a flush fit with the guards, not tucked in and not hanging out. Can anyone confirm if either of these sizes are correct?
18x10+20 or 18x9.5+22
If you have either of these sizes on your 32 I would be grateful if you could post close up pics of how they fit in the guards.
Edited by NISMATT
https://www.sau.com.au/forums/topic/405555-correct-wheel-size-r32-gtr/
They sit fine now but I have a 5mm spacer as the fronts rubbed the inside tyre wall without it, they came with the car and I have no idea what their offset is unfortunately.
So if +12 is dead flush, is +20 sitting in or out the guards?
I've got 18x10 +18 with my front and rear guards have been rolled and worked on. And it works perfect
Alright Deano any chance you could post some pics up for me so I know where they will be roughly?
Just super keen to know exactly how they will sit before I lay down nearly 4K.
Hi Matt, I run 18x9.5 +12 and they sit flush. (Tyres are 255/35/R18).
265's will scrub on the front but very minor on lock going slow.
I'll get some pics today
As per your first post
18x9.5 +22 will sit 10mm further in.
18x10 +20 will sit 2mm further in
Deano's 18x10 +18 will sit exactly the same as mine.
Hope some of the snaps help your choice
Richard thanks for the thorough response that was just what I was looking for.
Your fitment is pretty much spot on what I'm after so 2mm further in the guards I'll be stoked with, I run 255's on 10 inch wheels now so that's what I'll be using on the new rims.
  • 3 months later...
I am running CE28's 18x9.5 +15 with 265's all round.
Heaps of room! I could drive a truck through that guard gap.
I think a +12 would be better or a 18x10.5
(Uneven ground)
Edited by DarrenJC
  • Like 1
Hi guys I'm new to this forum and new to Skyline ownership. I've recently brought a 32 gtr and am looking to put new wheels on it but have a couple of questions I hope someone on here can help me with:
1. Will 19 x 9.5 +30 fit under the guards and clear the struts, or will there need to be some modifications done?
2. Does any one know how much a standard rim weighs? ( no tyre )
Unfortunately the car is not at my house so I can't measure distances etc and like many haven't quite grasped the offset concept yet.
I assume because the standard (16x8 +30) are the same offset as the rims I'm looking at that, they will just be .75 inch closer to the strut and the guard?
Cheers
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
