Hi guys might be a stupid question but what model gtr bov should you recommend or are they all the same?
I got defected with mine venting to atmo, I have an aftermarket plenum, stock bottom and aftermarket top half.
If my intake doesn't have a port to recirculate can I plumb it into my airbox? Or will that be not enough to pass defect clearance?
The air still gets remetered through the AFM. No go.
They both should be, the stock Stagea one I used ran 30psi fine once I plugged up the 4mm bleed hole with a grub screw. Now I have fitted the Turbosmart Kompact plumb back with a stiff spring. Its better but requires maintenance/lubing unlike the factory ones.
Well.. it was made for 13psi.. not 25psi.. Not sure if it will hold up and honestly not interesting in doing the test myself jsut to find out I have to re-do it agian because its leaking.
Just to explain how a BOV works and why more boost pressure shouldn't make it more likely to leak, the BOV has a diaphragm with a spring in it, so you have boost pressure on one side of it (the intake) and then you have boost pressure + spring pressure on the other side holding it closed (via the vac line)
So if you have 13psi running through your engine, you also have 13psi in the bov + spring pressure holding it closed, if you are running 25psi then you also have 25psi + spring holding it closed. So the more boost pressure you run, the more pressure is applied to keep it closed.
thanks!
I've got turbo smart dual port. The trumpet faces up on a 45 and was blowing the sound deadening on the bonnet apart. Removed the trumpet and blocked the port with a piece of ally so now it's full plumb back. Just another negative of atmo bov's
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
