Entries Open: Import Monster Sauvic Deca Motorkhana - September 8 2012
Proudly Presents:
Import Monster SAU-Vic DECA Motorkhana ROUND 3 of 4 of the 2012 DECA CHAMPIONSHIP
When : Saturday 8th September 2012
Where : DECA - Shepparton, 145 Wanganui Road, Shepparton, VIC 3630
Cost : $85
Max Entries: 50 + Reserves
-= PLEASE NOTE =-
The insurer of the event (AASA) has issued supplimentary regulations that require all entrants to wear helmets during all competition. This includes the skidpan and all battles.
This also impacts passengers, as they must wear a helmet prior to entering a competition vehicle.
A fire extinguisher is required by all entrants. This is for your own safety.
Please re-read the supplimentary regulations before entering the event.
Entry Form & Supp. Regs: ENTRY FORM
NO PAYMENT, YOU WILL NOT BE ON THE LIST
FILL OUT FORMS COMPLETELY. INCOMPLETE FORMS WILL NOT GO ONTO ENTRY LIST.
***Also, if you are emailing you entry, please name the attached file after your full name and what page it is. eg. 'Reon Staprey Disclaimer'.
Event Schedule:http://sau.ferni.net/DECA/128_Sep12/Sept2012Sched.pdf
Results: Not yet available
All withdrawles will be refunded after the event. Refunds will not be given after 5pm Monday 3rd september.
Anyone paying by cheque MUST make the cheque out to Skylines Australia Victoria. Cheques made out to anything else WILL BE REJECTED.
Please support our sponsors : Import Monster Pty. Ltd. Factory 3, 6 Wigan Road Bayswater VIC 3153 (03) 9008 0031
  • Replies 343
***IMPORTANT***
1) A reminder that anyone who does not have a licence (Cams or AASA) must bring with them, filled out and with $50 correct change, this form:
http://australianaut...PPLICATION1.pdf
2) GATES WILL BE OPEN AT 730AM. Given the amount of new people can everyone try to be at deca at 0730. The morning sessions are quite long so the earlier we get going, the more time we have for battles in the arvo.
3) Grouping requests: If you have anyone that you would like to be grouped with send me a PM and i will try to accommodate. Groups will be submitted at 2pm today 6/9/12 and cannot be changed after that.
4) Event Sched: http://sau.ferni.net...pt2012Sched.pdf
Entry List: As of 04/09/12
1 Import monster (Aaron) 86
2 Russell Cunninham I.M. #2 XR6T
3 Leon Stapley T1 180SX
4 Ryan Bell T1 180SX
5 Jake Lowry S14
6 Paul Stephenson R34 GTR
7 Ekaterina Glebova Evo 7
8 Chris Taylor Box
9 Clive Small Lancer
10 Liam Clements Pulsar
11 Joshua Robins Elfin
12 Jason Carey R33 GTST
13 Huy Tran Stagea
14 Bart Kohler R32 GTR
15 David Buntin Elise
16 Min Chan Elise
17 Simon Henman R33 GTST
18 Brent Germain R33 GTST
19 Jett Benson 180SX
20 Mathew Malusa EVO7
21 Adam Crane Chaser
22 Brad Insley Falcon
23 Michael Bourke VK
24 Robert Dyer R33 GTST
25 Mark Ryan R33 GTST
26 Gary Swift 180SX
27 Dickson Wu EVO?
28 Lloyd Waldron MR2
29 Chris Leermakers R33GTR
30 Daniel Scutella AE86
31 Jacqueline Sant S13
32 Daniel Daraxoglou R32GTS
33 Thai Long Chieu Corona
34 Owen Liberts R34GTT
35 Josh Miller R32GTST
36 Adis Sehic MR2
37 Johnny Rachele R32GTST
38 Matthew Borci R33GTST
39 Novic Popovic Supra
40 Jamie Carpenteri R34GTR
41 Matthew Hindle T2 180SX
42 Andrew Hindle T2 180SX
43 Jack Kuzior T3 R33GTR
44 Ash Cosgriff T3 R33GTR
45 Dylan Chauval 86
46 Shane Cummings Stanza
47 Evan Boaz R33GTST
48 Joshua Hindle Falcon
49 Joel Gregory Sti Forester
50 Sean Power R32GTST
Reserves
1 Cameron Dorn S13
2 George Kahrimanis WRX
Leroy, as good as it is to hear your coming to deca, nationals sounds like its will be worth coming along to!
I dont really want to drive 1400kms in the car and cant confirm a trailer until September. overall its a bit of a hassle, but I would have liked to go.
Guest
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
