Entries Open: Import Monster Sauvic Deca Motorkhana - September 8 2012
You AWD folks scaring me! Might take out my front shaft. :sweat:
That'll happen in one of the cabins full of boys, late on Saturday night I'd imagine...
errrrr what?! :3some:
  • Replies 343
hey, im keen to give this a go, will be my first event as a club member, iv had a read over the entry form, looks straight forward,
Only things im curious about, where has everyone else mounted there fire extinguishers? centre console lid? ......
And this AASA licence, i dont have one, whats involved on the day to get it? apart from the $50 dollar charge?
Looking forward to this!
Rob.
Hi Rob,
Print out page 2 of this form and bring it along with $50 on the day, They'll submit the form and payment for you. I'd say to apply directly to AASA, there's still time to do it before the event and recieve your membership card in time, but its better safe than sorry in case AASA processing is delayed for any reason.
http://australianaut...PPLICATION1.pdf
As for the fire extinguisher, it needs to be securely mounted within the car within reach of the driver.
It's been discussed many times before, but to summarise...
Get a 900gram+ Fire Extinguisher from Autobarn which has a metal for mounting. (~$40)
Go to bunnings/your shed and get some aluminium strap (1mm thick x 30mm wide x 50cm long) and.make a car bracket which runs between the passenger seat front bolts. Bolt (with decently strong bolts / washers) the extinguisher bracket to the car bracket.
If you position it right, it won't interfere with the seat movement along the rails, and it'll be easily accessible if needed.
Whenever anyone gets in your car for the first time they'll say "Why do you have a fire extinguisher?!" and you can casually reply "Because Racecar."
In the past some people would tek screw it to the floor or the trans tunnel or console lid. In an accident they'd rip out straight away. So this WILL NOT pass scrutineering on the day.
LOL because racecar, haha, thanks for that advice Simon, ill be doing exactly what you said with the front passenger seat bolts, will look professional and neat,
ill get on the AASA application straight away
Guys, will there be lockers or somewhere for us to unload our bags/stuff during the day?
Everyone leaves their stuff on the ground... it will be fine!
If you dont like that you could put it in one of the offices.... in anycase you'll be fine :yes:
Well I know how to drive, so it won't be a blown motor!
But i do have an issue with WD's. I can't remember more than about 5 consecutive things at any given moment... So I'll keep going with that failboating no doubt.
:thumbsup: Just like last time... team orange FTW. Again. And Again.
lol you know damn well if i didn't get that WD, I was equal first. Out & out cheaper/race car vs a streeter that's never run the course HOHOHOH MERRRY CHRISTMASSSSS :thumbsup:
Seems to be a trend with Ash, has it all in theory but just can't deliver :)
I bet he could make Jenna Jameson have a multiple orgasm, in theory.......
Thanks! My first time and not sure what to expect.
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
