Entries Open: Import Monster Sauvic Deca Motorkhana - September 8 2012
  • Replies 343
would I be better off bolting my fire extinguisher in? It's currently tek-screwed into my transmission tunnel
Yes. 2 x M6 high tensile bolts with washers. Easy...
That we wouldn't care about so much, however i would suggest something like velcro-ing it down so it doesnt get trashed..
The big picture is anything loose that can impede the driver or the operation of the car is a no no. Things that can get loose in the boot/behind you might not hit you but it can be a fair distraction. Its better to be concentrating on driving than wondering whats flying around back there..
Spare helmets are always a good one. First corner and you scare the crap out of yourself when it flies across the car ;)
With a battery in the boot it would have to be fairly secure in the box and box to floor yeah?
Mine was crap so I am making a decent cage to go into it which will be bolted down tight and a bracket over the battery will that do?
Sounds ok.
Make sure the positive terminal has insulation covering it. Especially if it's close to the metal bracket.
I plan on running some old 13 inch tyres on the back of my ae86. will this be ok?
Why wouldn't they be?
I know I'm cutting it fine but is there still any spots left for a GTS??
First timer here.
Put an entry form in mate. Hold off on payment though. If you get in, you can pay then. If you get in at 3rd on reserve list you're a good chance to get in.
Guest
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
