Entries Open: Import Monster Sauvic Deca Motorkhana - September 8 2012
  • Replies 343
I love straight-cut box
looks like rain should hold-off Saturday Sunday, maybe even some thunder friday night. should be good.
must remember to pack booze and sunscreen
Also, got a spare bed in a cabin for Friday & Saturday night if anyone needs to crash
if anyone is driving up on Sat morning, happy to meet at Wallan BP and go from there?
let me know! so we can all drive up and be sleep deprived together :)
***IMPORTANT***
1) A reminder that anyone who does not have a licence (Cams or AASA) must bring with them, filled out and with $50 correct change, this form:
http://australianaut...PPLICATION1.pdf
2) GATES WILL BE OPEN AT 730AM. Given the amount of new people can everyone try to be at deca at 0730. The morning sessions are quite long so the earlier we get going, the more time we have for battles in the arvo.
3) Grouping requests: If you have anyone that you would like to be grouped with send me a PM and i will try to accommodate. Groups will be submitted at 2pm today 6/9/12 and cannot be changed after that.
4) Event Sched: http://sau.ferni.net...pt2012Sched.pdf
  • 4. Apparel
    Competitors must wear non-flammable clothing extended from ankles to neck to wrists. Nylon clothing is not
    permitted. Shoes must be closed toe.
Just a reminder
Oh boy that last battle would of been soo good for the GTR! Nice drag race there.
All the setups look WAAYYY fun!
Good work blokes.
Spewing missing out on the Mega Mini!
Guest
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
