Entries Open: Import Monster Sauvic Deca Motorkhana - September 8 2012
Form asks for AASA licence number, I don't have it yet.... do i leave it blank?
Also, i can get my AASA licence on the day right? Was told it's about $50 and lastly how long do these AASA licence last for?
Thanks guys.
  • Replies 343
Thanks guys.
next to ASSA Licence number write TBA
yes can get it on the day its $50 and last 12months...long as paperwork is filled out before the day it will be ok.
I'm abit confused about the "Cars must be considered 'Roadworthy'" section.
My car has no leaks/drips, has all panels, seatbelts and fully working lights and the essentials but it's not legal in the performance parts aspect (Too low, too loud, wheels etc...)
May seem like a dumb question but roadworthy condition is a lot different to trackworthy condition..
you should be fine, as long as theres no dodgy stuff going on,
and nothing loose ANYWHERE, you'd be amazed how many people come through scrutineering with loose stuff in the car/boot/engine bay.
Guest
    • I'm interested if anyone agrees with what you've said, and can give a good reason. Temperature of powder coating should be below any temperature you'd use to alter the wheel structure.  Powder coat typically 200 to 250. Annealing if that's what people are claiming would be occuring, starts at 300, and depending on the alloy, can need even up at 400+.   That's the only part I can think of that could cause an issue that people are believing it's from the rim losing hardness and becoming too soft.
    • Negative probe should be on the cars chassis. Positive on the wire.   Start as said above by unplugging everything (unplug the lights, and switches. Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch. If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.   Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.
    • Anyone know if it's a problem to powder coat forged alloy wheel centers (Rays/Volk GT-C). some say it's bad and can damage the alloy, some say it's not a problem.
    • Hey guys, I'm reviving an old post but I'm finally getting around to working on this now. I removed the battery to get a better look at the wires and i traced the wires from the headlight to the fuse box in the engine bay, but the wiring looks fine? The wiring for the R/H headlight is 3 wires and then is bundled up with the large diameter wire that goes underneath the fuse box. I didn't take it apart yet. I know you said that its a short circuit somewhere between the fuse box and the headlight. But could it be the headlight switch on the dash? Also, i pulled out my multi-meter and set it on the Ohms, but i'm not sure where to put the negative probe and the positive probe.
    • I have a 2 lt in Sydney. It was fitted on a R33 GTR, not used for several years . If you are interested email me on: [email protected] I'm not on this forum much .
