Entries Open: Import Monster Sauvic Deca Motorkhana - September 8 2012
Well I know how to drive, so it won't be a blown motor!
But i do have an issue with WD's. I can't remember more than about 5 consecutive things at any given moment... So I'll keep going with that failboating no doubt.
lol you know damn well if i didn't get that WD, I was equal first. Out & out cheaper/race car vs a streeter that's never run the course HOHOHOH MERRRY CHRISTMASSSSS :thumbsup:
So they are going to let you out of the Big Brother house? ;)
AND..... you have 265 more KW's than i do :whistling:
  • Replies 343
All I can see is last years results.
http://sau.ferni.net/DECA/1119_Nov11/2011DecaChampFinal.pdf
where I seem to see a certain GTR being beaten in the 3 rounds he did By a S chassis on street tyres with ~50% the power
^ Would pay to see this!
Im imagining back to that time Daz drove Ryans car at the end of the day! :ph34r:
BTW S-Chassis are the peasants of the Nissan lineup. I dont see any S-Chassis that were $100,000 new! Why do you think theyre more common amoung drifters?! Dirty Drifters!!
very ture matt...
on the other hand at least when they break they dont stay off the road for 2 years... :whistling:
Anyway... more important matters .... Ash in RWD... that would be funny until turn 1 of the mini wang... :rolleyes:
FWD represent!
N chassis gonna smash some c***s :P (not really)
You can do well at DECA in a FWD, just look at Clive's results time after time in the little Lancer.
Just transfered payment, $50 as its my first time at deca, and im about to fax through the entry forms and transfer document,
Pumped!
Guest
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
