Well just at a glance, compared to mine,
its got a body kit thats not mentioned in the ad,
Indicators on the guards, i dont have,
Wheres the import plate and build plate? they should be there on the firewall but there not. so it could be really dodgy.
Speedo numbers are wonky, so the k's are whatever, who knows.
Another indication of lots of kay's is the seats were replaced with unworn ones, and the gearshift and handbrake boots.
I bouhgt a 12 year old volvo with 200,000 kay's and the interior is like new, so.... heaps of stuff will need replacing on an old 32
How old are they now, 22 years? If theyre sht they are sht i know i got one.
A bit harsh i know but be careful.
Ps there all sht compared to sins 32, so he cant tell.
:w00t:
Edited by D.I.Y. Mik
My GTR doesn't have indicators on the guards when others did.
I think some cars may have had them added when they came to the country.
As for seats and k's you never know what happens with these cars or what's been replaced it's really luck of the draw. Only thing you can do is get a mechanic or someone you can do to check it out and hope for the best really.
Thing is, they're at an age where if they haven't had things replaced they are shit. Even if they look pretty often they need a lot of work.
DIY Mick is spot on - Build and Import plates missing (Dodgey!!)
Speedo is aftermarket anyway. Add 40-60 thousand K's to the reading.
Side blinkers are at the discretion of the importer for compliance and local RTA during inspection.
Look for rust in and around the boot, lots of under body tar etc and like others have said, worn steering wheels, handbrake leather etc to indicate if kms are real.
Definently ask about the plate in the engine bay and compliance papers etc
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
