This is a client of mines Genuine Tommy Kaira R34 GTR, a little about this car and its features and specs.
This car is believed to be the only genuine Tommy Kaira in Australia and of less than 100 R34's ever done by Tommy Kaira.
With all original paper work showing this car went from Nissan to Tommy with 1,108km on the clock for the full overhaul and the car has been plaqued, the intake piping shows the car was 425ps after Tommy had worked their magic.
It has the extremely rare Tommy Digital Indicator System with digital speedo also, which upon speed recall shows a figure of (from memory) 382 kph or there abouts.
With only 28,xxxkm on the clock and full service history and books this car is truely one of a kind and was very exciting to work on.
Being a 425ps Tommy Kaira built GTR wasnt enough for the owner in Japan so he had a HKS Step 2 2.8 litre stroker installed with Greddy T517z turbos, KW Variant 3 coilovers, Titanium Trust exhaust, and a button activated clutchless shift racing system installed.
On hi boost this car turns out nearly 800whp and on low boost 550whp.
Oh and Ps that wing isn't for looks it creates enough down force that both mounting points have cracks in the paint around them from the boot flexing!
On to the pics!
Another rare thing is completely original glass around the whole car showing the serial number matching on each window.
Now housing a 2.8 stoker
  • 1 month later...
  • 4 weeks later...
Well done car looks imaculate
THanks
What a change!
Love the badge. Its a turtle right?
Certainly is a turtle :)
May I ask how many ??microns of paint thickness there were before the application of polish?
Very nice btw :)
About 80-90
Sorry for the late reply guys
    • Does it make a difference in your turbo having a shorter life if you have a cat converter as it causes that back pressure versus less/no back pressure with a decat? (Not sure if this is accurate) Also slightly different question if you went from a oem cat to a decat or vice versa will it require a tune? I heard if you change the dump pipe onwards it requires a tune?
    • No. Have only gotten as far as contemplating the task of having to put in the required fairly heavy wiring and fusing to run it (along with the big alternator), and preferring not to. But otherwise, it would be nice to have a little extra freedom as to exactly where the compressor is located and free up some space around the exhaust side of the engine.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
    • Bit off topic maybe but has anyone had a crack at one of those aftermarket electric compressors ? Bit of a search came up with one put out by Speedy Air Spares. Looks interesting and looks as if you'd have to run a big arse alternator. Found this out after the fact as my air con compressor packed it in and soon after my alternator ! !
    • Yes. Needs new ports. Usually just achieved by screwing an adapter onto them. Be aware that any AC compressor that hasn't been used in a long time will very likely have dried out seals and will not hold gas. Oh, and obviously you will require a new receiver-dryer also.
