I work at PNG Auto, 8 langford st pooraka . 8260 1111, if you could come down or we could meet somewhere after 5 ive got my cash ready (250) as my passenger backed out, im still keen tho
  • Replies 224
yeah that's correct Steve normal track days are $200 with the extra insurance its an extra $50 which is included in the $250 we charge
i hope thats a little clearer, its not another $50 on top of the $250
also each stint you can take a different person
na we run 3 groups of about 8 cars with about 12min rotations
too long on the rotations and we find people over heat brakes or just generally break shit
u going to have the evo out then?
ill try and come out
sky30 i have put you on the list you need to get back to me as soon as you can thanks
same with you Jin man you have shown interest with a question don't hesitate to speak up if you want a spot
we would hate to see someone miss out due to thinking they couldn't ask
yes. but as stated early. i work long hours and dont have time ( or a means of transport on my lunch break) to get to a bank.
i guess ill give the cash to someone to drop in the account
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
