I'm not a real fan of 33's, I don't have the money for a 34, and I'm only really after a GTR. I've had a Subaru, and the temperatures out here mean AWD is important to me. I've also owned a Sierra Cosworth, so really an R32 GTR is basically the better version of what I could get when I was in the UK.
Thanks all for the warm welcome.
Treeve
Work at Cadia, been in Orange for a couple of years (because of the mine).
I'm trying to learn about R32s as much as I can at the moment, but the worst issue is there aren't many around here for me to test drive, or even just speak to the owner. I guess that's the point of the forum - I talk to like minded people / owners and learn all the ins and outs so I don't end up buying a lemon.
I also have a second job, which may or may not make me popular. Current work loads means I don't really want any more customers though, so we'll leave it at that.
Cheers,
Treeve
hi Treeve be selective is the biggest peice of advice i can give you i only bought after looking for close to 18-19 months theres alot of crap out there that people will try and spin you stories about GTRs are a sports car they are going to have been driven as such ask questions you already know the answer to so you can gauge peoples reaction and help you fish for what there hiding every ones hiding something the depth is just the diffrence
Hey mate,
I have a Sierra RS cosworth and also spent a long time looking for a R32 GTR. Just bought one. I am in Melbourne but a guy one here named Fatz (who lives NSW) is a good help and a person worth listening to.
Lincoln.
Thanks for the advice guys. Cossy's are a lot more common in the UK - I picked up mine for £450 (yes, seriously, roughly $1,000 at the time!). I then stripped it and built a lotus 7 replica out of the bits. This car is now in my shed in NSW.
I've just had 2 guys in Orange let me look over their cars, and I've driven one. It was just like old times, and there were a few things which seemed a bit odd. I wasn't looking to buy either, just get a feel for them.
Is it typical for the gear stick to feel sloppy? Gear selection was a bit average, but even in gear the stick was all over the place.
Is there anything I should also keep an eye out for (ie do they rust in particular places, or does the suspension have issues?)
Engineers certificates for modifications - do most people bother getting engineer certificates, or am I most likely to find uncertified modification is typical?
I've got enough time to be picky, so I'll keep reading and see what comes along.
Thanks everyone,
Treeve
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
