FIRST OF ALL I HAVE SEARCHED AND DID NOT FIND THE ANSWERS I WANTED. THANK YOU.
Now with that out the way i recently decided that i wanted to go single with my GT-R this is something i have always dreamed of. My current setup is capable of 400kw at all four wheels therefore whilst iam going down the single path i want it to be worth the money and time so i want a set-up which will give me 450KW+ on all four wheels which will justify the cash put into the car. I have been doing ALOT of research on turbos and trying to find as much videos on youtube and dyno sheets to do comparisons.
It has come down to these two turbos the HKS T04Z or a Precision 65-66 series turbo. I would prefer to go with a precision serie turbo as it is new tech compared to the old but yet proven T04Z but im not sure on what size i should get..
What i want from the car:
450+ KW on all 4
Car will be a dedicated E85 car
Mid and Top end power: The laggiest id want it to be is MAX 5000rpm (full boost)
Whats on my shopping list:
Powertune Double Fed Fuel Rail
Powertune Twin-In Tank Fuel Set-Up: Including the twin walbro's that come with the package
Powertune FPR
ID 1000cc Injectors
HKS Cam Gears
HKS Step 2 Camshafts: Also again not sure on what lift i should get or if i should get Step 2's at all, the car currently has Step 1's
Greddy Intake Manifold? Do i need it?
Plenum? Go custom or off the shelf ?
4inch Dump-Pipe + 4inch Exhaust
I dont want to go throwing my money down the drain that is why i will greatly appreciate advice cheers.
https://www.sau.com.au/forums/topic/405650-turbo-upgrade-need-opinionsadvice/
  • Replies 41
Posted Images
Straight up I can say you're going to need bigger injectors if you want 450rwkw on E85
He actually wants 450kW @ all 4, not at the rears. So in excess of 500-550kW at the flywheel.
1600cc injectors to be safe?
Well you know that "plenum" and "intake manifold" are the same part right......so that saved you some money haha. Use the stock plenum though.
You'll need a quality intercooler and good piping if you haven't got one already.
Forget the TO4Z, it's too outdated.
For cams I'd go as close as you can get to 260 degrees and as much lift as possible.
The older HKS cam gears had issues with reliability, so most choose tomei as they just work no questions asked.
Injector Dynamics 2000's, forget 1000's/1600's.
Hope you've got a good engine builder and tuner too! All the best parts in the world won't help if the tuner and builder doesn't know what he/she is doing.
Which turbo should i go for then? Precision 6766? The car currently has 264 cams and a 4inch FMIC. Im not worried about the tuning/builder as i trust the workshop/tuner that i go to and im very anal so it wasnt easy to find someone i could trust. Im more worried about getting the correct turbo + cam setup.
Why MUST it be a single?
It MUST be a single cause it is what ive always wanted. A single turbo GT-R! -5's are great for what they are but i need to go single. It has to be done lol.
Who's your builder/tuner?
The 6766 etc size are all going to make 450kw easy enough going off previous results, but they go on to make much more hp if you aren't afraid to screw boost into them.
I'd go a 6262 or something a tiny bit bigger, twin scroll of course end of the day you could always go for what you think will be good and change easily enough later on. These turbos aren't expensive which is good because you'll always be able to sell what you've got and get a new one for a small changeover cost
If the 6262 gives me 450awkw with ease and close to or if not 500awkw when im pushing it il be happy with that. The builder is Edge motorsports, im not quiet sure what kind of rep he has on here but ive had many dealings with him great service and work. As for the Tuner im getting ETuner to tune my car, i know he has mixed reviews with people but ive watched him tune a few cars spoke to the owners 1-4weeks after the tune and they all seemed happy. If iam not happy with the results i will head down to Status i have been told that Trent is pretty good with GT-R's.
I'd have a look at the new 6264
Meant to be a ripper
I definitely will cheers.
Edited by Sedat
It depends how the dyno is setup, I lost 30kw at least as he set up the correction at .7 for awd and .9 for rear. Makes it hard to judge the gains.
Cihan knows his shit, if you chose the right combination you should be set. ;)
Never heard of those shops, distance would be the reason of course.
How about you wait a bit, DVSJEZ is doing a 6262 currently so wait to see his results and that can help with a bit of a baseline. He is on E85 too.
Got a good ECU sorted? What about a gearbox and brakes?
I purchased my car off a very well known forum member "RBWARE". The car has many quality parts and is basically ready for a single turbo set-up, all it needs is a beefier fuel set-up which i have covered.
I sent DVSJEZ a PM iam awaiting reply from him.
Here is a quick run down of the mods: Mind you the HPI dump pipes are not installed still brand new in the box and will be sold.
Block:
Block Balanced
Crank Tested
Acid Dipped
Blue Printed
CP Forged Pistons
Eagle Forged Rods
Heads:
R34 GT-R Head
Rebuilt/Cleaned
ARP Head Bolts
3-Layer Copper Head Gasket
Cams:
HKS 264 step 1 Cams
ISC Cam Gears
Induction:
GT2680R-5 x2
HKS 4inch FMIC
HKS Turbo Gaskets
HPI Dump Pipes
Aftermarket 3.1 inch Front Pipes (unsure of brand)
Custom made 3.5 inch Cat-Back
JUN BL Muffler With 4inch Tip
Greddy Hard Pipe Kit
Drift Pod Filters
Fueling:
Bosch 800cc Injectors
Stock Fuel Rail
Nismo Fuel Reg
Bosch 040 Internal Fuel Pump
Oil Mods:
Trust Oil Cooler
Custom Oil Catch Can
Baffled Sump
N1 Oil Pump
N1 Water Pump
Suspension Mods:
Tein Coilovers
Cusco Adj. Caster Rods
Whiteline Sway bar's Front & Rear
JIC Upper Adj. Camber Arms
ISC Hicas Lock Bar
Braking:
AP Racing 4 Spot Front Brakes
Brembo 2 Spot Rear Brakes
Endless Brake Pads
Slotted Rotors
Braided Brake Lines
Motul Brake Fluid
Electronics:
Haltech PRO Platinum ECU
Blitz EBC
    • Just checking, when we are talking about high temp fluid, are we all referring to DOT 5.1? I haven't had any issues with changing it every 2-3 years.
    • Yeah that is still true AFAIK.....good brake fluid should be changed annually because it absorbs water faster which is more often than most mechanics would do it. There are cheap tools that check water% in brake fluid if you all scientific about it. I for sure would (do) run good brake fluid in anything that even casually saw the track like Murray said; avoiding the risk of "exciting" fade is worth it
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
