So i'm about to pull the trigger on these rims - http://www.nlmotoring.com/product-p/52100142n.htm
20''x10.5 +30mm offset 3.25'' lip depth, if i were to purchase these, would i need to get my guards rolled with 235/245 f & r? The car is NOT lowered at all.
Thanks
https://www.sau.com.au/forums/topic/405709-xxr-rims/
Will fit fine, they will have minimal poke what tyre profile would you be running?
I currently have a 255/35 on a 20x10.5 +17 on the rear of my 35, at standard height and it is in the guard.
I highly doubt you will need guard work at standard height.
+30 is not aggressive on a v35.
your more than likely going to have inner clearance issues before you hit the guard.
https://www.sau.com.au/forums/topic/405709-xxr-rims/#findComment-6462535
It's a bit tricky to get my head around the rim/tyre fitments. so when it's 20x10.5 +30mm lip. Is the LOWER the lip the more dish or is it the higher? also with the 10.5 width is it better to be higher or lower? Confusing as all hell!
https://www.sau.com.au/forums/topic/405709-xxr-rims/#findComment-6462639
Lip has nothing to do with offset. The style of the rim spoke dictates lip (but in general the lower the offset the more lip).
However as I said it is about rim design - you can get XD9s in +30mm offset and they have buttloads of lip due to the spoke design, whereas a rim like the Work Kais will have little to no lip even in +12 offset.
Confused yet?
https://www.sau.com.au/forums/topic/405709-xxr-rims/#findComment-6462688
Confused yet?
HAHA yes you have successfully confused me. So an offset of 8.5 is going to have more dish/lip than 10.5 yes?
arent you in a sedan mate?
No mate, coupe
https://www.sau.com.au/forums/topic/405709-xxr-rims/#findComment-6463150
The offset defines where the mounting point on the wheel is. Offset of 0mm means that it's smack bang in the centre of the wheel. +30 means that the mounting point is further forward and -30 means that's the mounting point is further to the back. So the lower the offset the more fish - design dependent though.
https://www.sau.com.au/forums/topic/405709-xxr-rims/#findComment-6463202
and before you pull the trigger there is also caliper/disk clearance you have to worry about. Wheels with big dish are normally lo disk clearance...thats why u see most staggered setups have more dish at the rear than the fronts.
Most Jap wheels will specify this....not sure about XXR though.
https://www.sau.com.au/forums/topic/405709-xxr-rims/#findComment-6463870
Basically what i want to do is make the wheel flush with the guard or even have a little bit of poke, however i have just found out my mate has a proper setup so that guards can be rolled so it's not a massive issue anymore if the wheel is too big.
I would love the rim to hang over the wheel a little bit too..
These calculators aren't making any sense to me at all, I'm now looking at 20x8.5 + 22mm offset with 20x9 or 9.5 at the back same offset. How would this look?
Apologies for the very noob questions wheels & rims just aren't my forte.
https://www.sau.com.au/forums/topic/405709-xxr-rims/#findComment-6465538
The above offsets for a coupe would definately fit but is pretty conservative.
Have a look here for some ideas: http://rimtuck.com/search/thumbnails&make=Infiniti&model=G35+coupe&sort=1
Bear in mind most of these are slammed and lowered quite a fair bit. Question is how much are you lowered if any at all?
rule of thumb, the lower you go, the more you can squeeze into your guards as it will give you more camber like so ------> /oo\
To get the desired look you are after, you have to lower your car even if its a mild drop otherwise you will be sporting the 4WD stance...:)
https://www.sau.com.au/forums/topic/405709-xxr-rims/#findComment-6465585
Have a look here for some ideas: http://rimtuck.com/s...35+coupe&sort=1
To get the desired look you are after, you have to lower your car even if its a mild drop otherwise you will be sporting the 4WD stance... :)
Thanks heaps for that link i will look at it shortly just at work, not lowered at all mate. Surely it's possible to slap some 20's on and have a bit of poke with stock suspension? my mate has 20s with stock suspension but they don't fit flush with the guard they are a little bit inside and i don't really like that :/
https://www.sau.com.au/forums/topic/405709-xxr-rims/#findComment-6465610
    • Been over 2 months since I have done anything on the S15 and had a day off today so got stuck into mounting the radiator and intercooler. I ended up using factory bottom mounts as bolted in and I did order some gktech top brackets but didn't work with the PWR radiator so made up some with aluminium flat bar. Spent way to long on them but pretty happy how they are. Next job was the intercooler. Used some more aluminium flat bar and did the bottom mounts first. Top was easy as just one long piece and 2 90 degree coming off rad support and welded them on. The bumper support required some notching to let the outlets sit where I want so will add some reinforcement later to strengthen it. I have also bought ecu and waiting for it to arrive. Went with a Link g4x Xtreme but will be adding a ptmotorsport expander to add a few extra inputs over CAN. Went through a few different configurations on pclink to get what I want to allow future expansion for sensors and gearbox upgrades. Ordered gktech rear arms but looking at the hardrace lower control arms to have some extra adjustment too will see how the alignment looks after first setup. Got 2 more weeks of work before shut down and will have almost 4 weeks to work on this so planning on hopefully firing up mid January.   Also bought a 2015 brz with a heap of good gear, did noosa hill climb a month back. Owned it for 3 days changed alignment and sent it. Finished the weekend 2nd in class and only .3 off the 180sx best time last year. MCA Red coilovers, gktech rear lca, bolt on lock kit and tie rods, whiteline toe arms, cusco 1.5way diff and 4.5 ratio, endless brake pads, headers, exhaust, perrin intake and e85 tune. Electronic steering adjustment, nankang crs with koya wheels 17x9 +35. Have bought rear traction arm and relocation kit, extended studs and v3 tie rod kit. Planning on also getting flex tune as lucky to get 300km a tank with e85 and short ratio. Car is a heap of fun to drive and super easy to work on. AC in the line up at Noosa was mint in 35degree weather.
    • I'm 22 years younger than you mark, and I'm operating in the exact same way! Ha ha ha
    • All clamps are oem    one question is , what is the bit at the top on high pressure pipe where it connectes to intake manifold and other side goes toward the engine( see item in red circle in diabram attached)   ? Seen some people stating that should be removed on boosted application and skyline is boosted from manufacture so little puzzled. Mine is around 23pwi (700 hpish)   also some state it could be the bonjo bolt crash washer so bought two washers
    • what do you mean dead platform? People buy older, out dated and less power cars on "Dead platforms" for over $65k all the time.
    • That is really nice! Very nice finish when you have an oven to do the crinkling nice and evenly!
