SLYDIT Posted July 27, 2012 Share Posted July 27, 2012 Can anyone direct me to a wiring diagram for an R32? i am trying to install an alarm and immobiliser into the car and am looking for the best place to get a 12v and ACC power at the back of the car (hicas or attessa ecu???).also if anyone would like to PM me what they think is the best circuit to disable the car that would be great.I am also having trouble getting the trim out of the rear of the coupe and even the rear seat seems to not want to come out.I am doing this for a mate and he wants his car back in a week. ( i have already wasted a week waiting for my account at SDU to be activated...AAAARRRGGGHHH!) Link to comment https://www.sau.com.au/forums/topic/405735-r32-gts4-wiring-help-urgent/ Share on other sites More sharing options...
Carbon 34 Posted July 27, 2012 Share Posted July 27, 2012 Give him his car back , your begging for bad things to happen if your stuck already and never pull power off ecu's for anything where did you buy the alarm they should help you or shouldnt have sold it without install to start with Sorry but alarms are best left to pro's in 99% of the cases home install ends in failure Link to comment https://www.sau.com.au/forums/topic/405735-r32-gts4-wiring-help-urgent/#findComment-6463173 Share on other sites More sharing options...
SLYDIT Posted July 28, 2012 Author Share Posted July 28, 2012 (edited) i'm a sparky so wiring is not a problem. the alarm that is currently installed by a "pro" is a JOKE and could be found and disabled in seconds. Ive never worked on a skyline but have installed and tuned ECU's before. ( I have a turbo'd MX5) i just want to get the GPS tracker installed and hidden much much better than the "pro" did the alarm install. I figure it was better to pick a 12v and acc feed from the ones feeding the rear electronics rather than run non standard wires to the front.What about the plug that feeds the "active speaker" amp? as i have trawled the net for info and diags i have come the realsiation that the skyline world has very little info available compared to the usual car places i hang out. not knowing the skyline wiring inside out i figured here would be a good place to start Edited July 28, 2012 by SLYDIT Link to comment https://www.sau.com.au/forums/topic/405735-r32-gts4-wiring-help-urgent/#findComment-6463423 Share on other sites More sharing options...
Carbon 34 Posted July 28, 2012 Share Posted July 28, 2012 (edited) Your right the word "pro" is vauge just because a Car audio or alarm shop installed it doesnt mean its right , but a 12v sparky is even worse lol sorry its true , i'm sure theyre is exceptions around ? And mobile installers are fine for somethings but not for a well hidden job it just takes too long to do it from a van in crap weather while customer stands above them Your giving away the location of the items on the Net too now not wise Like I said do not pull ground or power off any ecu items or weird things happen some fatal to owner or car and hard to figure out once hacked by items that dont belong hooked up to those and no fuel related items either , nissans have low voltage conditions from ecu transistor and can drop well below 12v running which would be fatal to ecu and most likely tracker most GPS trackers are slammed in or substandard jaycar plastic models that arent up to australian conditions longterm , real installers would hide it so well even the dealer wouldnt find it looking all day long !!! Edited July 28, 2012 by Carbon 34 Link to comment https://www.sau.com.au/forums/topic/405735-r32-gts4-wiring-help-urgent/#findComment-6463583 Share on other sites More sharing options...
Chris Rogers Posted July 28, 2012 Share Posted July 28, 2012 and you live where? Link to comment https://www.sau.com.au/forums/topic/405735-r32-gts4-wiring-help-urgent/#findComment-6463600 Share on other sites More sharing options...
pigsh1t Posted July 31, 2012 Share Posted July 31, 2012 best place to hide it is behind speedo cluster can not be seen from under dash and cant be tampered with or power disabled without disconecting battery but the gps shuld have battery back up and if it doesnt your wasting your time installing it Link to comment https://www.sau.com.au/forums/topic/405735-r32-gts4-wiring-help-urgent/#findComment-6468103 Share on other sites More sharing options...
Carbon 34 Posted July 31, 2012 Share Posted July 31, 2012 best place to hide it is behind speedo cluster can not be seen from under dash and cant be tampered with or power disabled without disconecting battery but the gps shuld have battery back up and if it doesnt your wasting your time installing it Yeah cool story bro Worse place to put it Your a mupppet we dont disclose security details in a public forum car theft is bad enough without help from wanna be "pro installers " Try being helpful in other ways ffs And we tend not to want DIY car security installs because 99% get it wrong , nobody likes to fix someone elses mess when it comes to alarms Link to comment https://www.sau.com.au/forums/topic/405735-r32-gts4-wiring-help-urgent/#findComment-6468816 Share on other sites More sharing options...
SLYDIT Posted August 3, 2012 Author Share Posted August 3, 2012 i am quite happy for people to reply to me via private message. i have everything installed except the immobiliser circuit. id like to immobilise the fuel pump but cannot find the wire in the loom. If someone would like to be helpful and tell me where/what colour it is that would be great (PM me) Link to comment https://www.sau.com.au/forums/topic/405735-r32-gts4-wiring-help-urgent/#findComment-6473071 Share on other sites More sharing options...
Carbon 34 Posted August 3, 2012 Share Posted August 3, 2012 i am quite happy for people to reply to me via private message. i have everything installed except the immobiliser circuit. id like to immobilise the fuel pump but cannot find the wire in the loom. If someone would like to be helpful and tell me where/what colour it is that would be great (PM me) So let me get this right your a sparky for 12v and cant find the fuel pump wire or google it properly ? Seriously step away from the car and do not help anyone until your better trained on how a car works and how to interface the systems without damage or danger to the owner or car I tell it like I see it I'm being a dick for a reason , to save someone heartache from bad advice , not to attack you personally ( not everone knows it all and never will ) but the warning signs are in about your skill level thank you come again Link to comment https://www.sau.com.au/forums/topic/405735-r32-gts4-wiring-help-urgent/#findComment-6473273 Share on other sites More sharing options...
SLYDIT Posted August 3, 2012 Author Share Posted August 3, 2012 (edited) no i am an industrial sparky with advanced trade wit h15 years experience in medical and process control WHO DOESNT HAVE TIME to pull the rear of the car apart looking at every plug connection to find the fuel pump wiring...like i said i was pushed for time and needed it done...... too f**ken late now thanks for being such a farken smartass. you could have just answered the question and given me the info that i needed but no..... you decided to be a know it all. thanks for nothing. now i know why i dont own a skyline. muppet. Edited August 3, 2012 by SLYDIT Link to comment https://www.sau.com.au/forums/topic/405735-r32-gts4-wiring-help-urgent/#findComment-6473333 Share on other sites More sharing options...
Carbon 34 Posted August 4, 2012 Share Posted August 4, 2012 (edited) Your welcome Genius a skyline wins again lol Edited August 4, 2012 by Carbon 34 Link to comment https://www.sau.com.au/forums/topic/405735-r32-gts4-wiring-help-urgent/#findComment-6473497 Share on other sites More sharing options...
