yeah i know hes in AUS :) So am i lol. But im a nice guy and would have sent it anyway :P
And too true.. Bolts generally end up permanent for me too. I had a wine cork blocking my BOV return for over a year :)
Thanks heaps guys! Really do appreciate all the help so far! Great to see a forum that has good people on it! Will try my mech tomorrow about "bunging" it. I seriously hope that fixes the issue. REALLY don't wanna fork out for a rebuild or it gonna be spaghetti for me for the next few months O_o
Curious to know about silicone, I'd say your assumption would be spot on though.
One question, if I ditch the catch can, what will all that oil do if I just run the pipe from one of the top pipes to the othe (factory I assume) will it bellow smoke?
Edited by Spooger
If you want to block a fitting, I use the stoppers that they put on the ends of chair legs, they work a treat and come in all different sizes.
If I leave my car for a few months without starting it the condensation gets pretty rough and it'll breathe a lot of steam, I just let it idle with the oil cooler covered in cardboard off so the oil gets nice and hot and boils all the water out.
They dyno'd it but they only ran it at 8-10 pound. I'm at a loss, I can see these guys rubbing their hands together licking their lips at the money the want to make off me. They claim they can't print off the specs off their dyno'd machine as I asked for them. I don't know if I trust them or not. They said it has a shitload of blow by yet when I have checked it, it was minimal! Hulp!! What do I do? I'm in a regional area and we have only 2 places who know (sorta) how to work on these.
Edited by Spooger
Ok I searched high and low, repco, Burton's, super cheap, autobahn, and even Clark's rubber. No one has something to block the Pcv outlet off the rocket cover.
remove rocker cover, take somewhere to be hot washed and have the hole welded up if you want it blocked, a bolt in the hole doesnt give a fantastic seal and will leak.
8-10psi would be normal for a stock engine.. but not giving you a print out sounds dodgy.
Excessive blow by is when your dipstick gets blown out of the tube!
You need to do a compression test. Any workshop can do that or you can buy or borrow a compression gauge and do it yourself. You say you are in a regional area - how regional? It always helps to put the town where you live (or the nearest town) so that (a) another member might be nearby and be able to have a look at your car and (b) people can recommend the nearest good workshop. If there is one within a day's drive that might be a good idea before you give up on the car.
If you get a workshop to do a compression test ask them if they can do a leak-down test. It should only be an hour's labour charge. The results should tell you if the motor needs to come out or not.
  • 3 months later...
No, no, no, no, no.
Starting at the PCV fitting, you should have:
PCV to intake rocker cover (as per factory fittings)
Intake rocker cover to exhaust rocker cover (as per factory fittings)
exhaust rocker cover to catch can
catch can to intake side of turbo.
Ditch the stupid filter on the can (and plug the hole).
So basically, the catch can replaces the hose that goes from the exhaust rocker cover down to the intake of the turbo. And the whole system remains sealed and does not vent to atmosphere. And you don't have problems with EPA.
This has to be THE best and easiest explanation to installing a catch can EVER on a RB engine.
Thank you!
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
