Hey guys not sure where else to put this so here it is.
I've recently got myself a new gopro hero hd 2. Have filmed a bit of footage on it but its been mostly 4x4 slow pace stuff using the suction cup mount.
Just wondering if anyone has one of these (I got the motorsports edition kit, with the suction cup). I was chasing feedback from anyone who has used this particular mount for high speeds motorsport. It has the 3m sticky pads but don't want to stick them all over my car if I don't have to.
Would appreciate feedback.
Maybe also a place where ppl can post up some footage filmed off there go pros
https://www.sau.com.au/forums/topic/405770-go-pro/
Check that out i had 2 go pro's mounted on my car one on the inside mounted to cage and the other on the roof with suction cap, both were rock solid 145mph and full RPM launches didn't phase them highly recommend them.
  • Like 1
https://www.sau.com.au/forums/topic/405770-go-pro/#findComment-6463822
Using it for powercruise mate so hopefully reaching speeds of 200+. I know qr is rough but im guessing rally is worse lol. I just wasn't keen on 400 bucks worth of camera falling off my car and getting run over. Hey nur33 that link wont open on my tablet but will check it out, god I love ur car I read the article in hpi I think it was a few months back.
https://www.sau.com.au/forums/topic/405770-go-pro/#findComment-6464052
I've used the 3pod Camzilla at all kinds of tracks - including a 220kph pass @ oran park. Just make sure it's on a good clean flat section and go for it.
BTW - the lower the angle the "faster" things appear. I have one of those 3M pads in the front intercooler air intake area - always looks great!
https://www.sau.com.au/forums/topic/405770-go-pro/#findComment-6464162
Get the double suction mount (way better stability) from here:
http://www.camzilla.com.au/products/suction-mounts
and get the GoPro accessory from here:
http://www.camzilla.com.au/products/mount-accessories
Just ordered both of these, thanks heaps for the link. Definitely considering buying a second go pro to do the dual videos. Love the idea of mounting one in the front mount area would be sweet and fast.
Wat editing programs do u use, tried using windows movie maker as it was already on my comp but it was painful to do so.
https://www.sau.com.au/forums/topic/405770-go-pro/#findComment-6464185
i mostly use my gopro for stills these days (point and shoot fisheye camera ftw!) but I recorded a little bit with it. i used the imovie app on my mac, not the best app, but does the job for simple edits...
Edited by Jay019
https://www.sau.com.au/forums/topic/405770-go-pro/#findComment-6464412
I use Corel Video Studio for editing. The big key is that it is way easier to learn than premier or final cut pro (pro level editing software). It is a mid range package around $120 (buy on-line!). Does the job pretty well for us amatures.
As for slow motion - do a bit of research. I'm saving up for a new GoPro Hero 2 - it does 120fps in 480p. Slow that down to 30fps and get 4x slow motion. The trick with slow motion is to get software that can pull the frames out so you don't lose them. A lot of software just holds a frame for 3-4 times longer giving jerky motion.
https://www.sau.com.au/forums/topic/405770-go-pro/#findComment-6466661
  • 1 month later...
I have searched go pro and this thread.... didnt come up lol but found it so thought to ask advice here rather than start a new thread.
Ive just bought an HD Hero 2 Motorsport also. After hiring one for a track day from pezhead I decided to buy my own. Scored it for $269!! I have taken some footage on it just around the house and the footage is very jerky and grainy when I play it on the computer. I have it set to 1080 and using a 16gb sandisk extreme up to 45 mb/s card. Also the footage I received on disc from my track day is the same. The promo video on the gopro website is unreal quality. Whats going wrong? Could it be as simple as needing a better Graphics card in the computer? I did try the disc footage on another PC which was grainy but smooth.
If anyone knows please help. Thanks
Liam
https://www.sau.com.au/forums/topic/405770-go-pro/#findComment-6553705
Yeah it'll be a codec issue most likely on the PC itself.
MPC-HC is where it's at (Media Player Classic - Home Cinema), out of the box it'll probably be ok actually without any codecs.
You get a zillion options with MPC-HC as well if you want to do post processing and so real time on without the need to run it via video editing packages. Packages obviously do a better job, depends what you want etc.
All the go pro stuff I have looks perfect right off the card
https://www.sau.com.au/forums/topic/405770-go-pro/#findComment-6561468
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
    • I hate it, but maybe he could paint it Monster jam style and call it...godzilla?
    • Would seem to me to be appropriate to go GTR style bar. There are options with and without N1 vent holes, with the GTR lower lip integral (because FG copy). https://justjap.com/search?q=r32 bumper
