1994 R33gtst complete part out.
After market kit includes
garret 35/82 ext gate turbo on custom low mount manifold with 60 mil gate plumb back and full 3 inch exhaust system through to rear cannon. Includes all water and oil lines And near new 4 inch bmc pod filter, Just bolt it on and go......2000 dollars takes the complete ready to bolt on hotside from filter to cannon.
Large alloy radiator in as new condition...175 dollars
100 mil cooling pro intercooler as brand new...250 dollars
Apexi 2 bar boost guage on a pillar mount with controller complete..... 150 dollars
Tial atmo bov vband clamp included.....75 dollars
Reconditioned diff (ERD) with new bearings, lapping and shim pack. buy a shitty one for a hundred or this one with peace of mind for .....250 dollars
Nismo chrome shift knob .....50 dollars
NPC big mouth single plate big hp clutch pressure plate and flywheel, the best of the best for street application, done less than 500 kays....500 dollars
The best 5 piece set of nissan skyline floor mats you will ever see complete with metal badges......150 dollars
DTM shadow chrome 18 inch wheels and tyres, one wheel has some rash and chrome peel but all in good nick no buckles or cracks, tyres are khumo 265 rear 40% tread fronts are 245 khumo with at least 75% tread....500 dollars the lot.
Genuine autech Rear wing complete with brake light, Rare piece here.....250 dollars
Heaps of audi gear at bargain prices, a sub the size of a fridge, amp, head unit, havnt checkded speakers but there is a front pair only, heaps of wiring, relays fuses etc. .....100 dollars the lot.
Set of 550 cc hard to find side feed injectors, yellow top, Unsure of brand but will rectify that.....450 dollars
HKS coilovers, fully adjustable with c spanner and adjustment tool, great condition....750 dollars
Factory plastic rear pods in perfect nick....100 dollars
Factory side skirts in great nick with one crack on the front of the passenger side, simple plastic weld fix....125 dollars
Its a complete car so anything you may be interested in just hit me up.
As it stands only the gearbox and tailshaft is sold so first in best dressed on everything else. engine, brakes, electrics, body parts etc, its all there.
contact on 0413863207 any time
https://www.sau.com.au/forums/topic/405802-rr-gtst-partout/
  • 4 months later...
    • I mean, I can confirm the TPS is at 100%.... I can confirm when we installed the TB and setup the cable that the TB was indeed fully open at max pedal travel.. the same 'curve' (WRT MAP vs MAP) existed with the previous setup/TB/manifold as well... No, we did not do a run with no intake connected. I would love to go back in time to do such a run to rule out the intake. It would have also been good to do a run with the airbox lid off. There's a test there where increased IAT vs more available air could be a positive tradeoff. I remember taking the lid off my R34 Turbo setup back in the day and noticing a monster increase, even if IAT's did go up. Could be similar. Hard to test unless I find a very deserted road.
    • That's actually encouraging to be honest. my motor was rebuild many years ago but it's probably done less than 30,000kms and fucc all limiter or drift, majority street / drag / roll racing. It'll be fine 馃挭馃徏 I don't even have lines or a can for the cam breathers installed yet, there is zero oil residue or splatter on or around them, it drives beautifully so it seems healthy. Just a ticky lifter, yet they're almost brand new oem genuine Nissan and haven't done many kms at all...
    • Have you confirmed the throttle body goes to WOT (and stays there) during the run?
    • I'm having a problem. I think it was mentioned above somewhere but can't see it.  I'm stuck in the cycle of, sand, filler, low spot again, put filler, sand, low spot again, now i put filler again and a thicker portion which seems to have helped but I got low spots in other areas. In the image. Circled in red thats where the original low spot was and the shape is the same as the red out line. I've more or less fixed that (still low spot up the top but now I have low spots where the green circled part is.  Is likely the issue that I didn't start with a course sand paper? I sanded the filler with 240 to reduce the risk of not going to far but maybe the issue is that I'm only taking off enough material to remove some of the filler but not the high spots. I now started sanding with 120 and I think I'm seeing a difference. I did fix one dent the other 2 are f**ked and seems like I made another low spot which is indicated by the furthest green circle on the left handside. Any thoughts and solutions?   Also second image. All of these rock chips, can they be filled in with primer or do i need to fill them all with filler/putty? So many rock chips on mine lol.
    • Well, I had an Edward Lee's special edition odo windback car/motor with a RB25DET S2 and I put down 372kW with a good amount of track abuse for 1.5 years before the ring lands decided it didn't want to stick around anymore 馃ゲ But probably didn't help I kept on smashing try limiter on the track and a few skid pans.
