hey guys,
While I love my V35 she's got some sore points that i've just dealt with, but wanted to know if others had the same issue.
Basically I find the headlights in it arent strong enough..
HID yes, thats great, but driving i get what seems like only 6-10m of visibilty out of them if the road is pitch black..
I can jump in my partners mitsub mirage and the headlights on that light everything up like its xmas...
anyone else have this issue ??? I just wanna know if its a common thing, (2003 model / 6spd man) or if its just the lights they come with arent that strong?
are we able to upgrade them without causing mass drama?
Also I have no button to increase my dash lights brightness, I know where it is supposed to be, next to the boot release switch..
problem is there is another button there, I will take a photo and post it up, but its a button that has a picture of what looks like windscreen with a squiggle line across it... ???
anyone else have that in their car ? I have no idea what it does when I press it at all... short of pulling the dash apart to trace it :(
thanks everyone
The dash lights are auto.
You can tilt your lights up. There are two "bolts" that you can turn to tilt them up. They are on the back of the lights. Hard to get to but it can be done.
Just wondering, I got 06 coupe, comes with xenon projector/HID if I want to change the bulb to say 6000k 55w can I just buy those HID bulbs say from eBay will it be a straight replacement? Do I need to buy like a separate ballast?
ebay hid kits are generally not interchangeable.
you need to firstly check the bulb type currently fitted (probably D2R) and then order a pair of those in 6000k
but as per usual with ebay - cheaper is cheaper. buy chinese and youll still be squinting
the main thing to work out is why yours are currently poor. its not normal. as said before, get the beam alignment checked. if youre in adelaide i can help
Edited by Deep Dish V35
hey guys,
thanks for the responses, nah I'm in brisbane, thanks for the offer though..
I spent a while tonight going to town on the lights with meguirs plastic cleaner to try see if that would help a bit, they were getting a bit 'grubby', took her for a drive and that seemed to improve it a little bit... not sure if they need to be pointed up much, as driving along road signs light up perfectly fine in the distance, just the light on the ground etc doenst seem "strong"..
I may very well be comparing this to cars like accords etc whose headlights seem to be almost floodlights ..I'd love to compare to some peop in brisbane perhaps, i may very well be expecting more from it than what its gonna give :) hehe
as for the mystery button, I thought it may be a windshield demister button as well, that would explain the button...
I know the dash lights are auto, i'm just picky and would like them brigher when the lights actually come on..
if you want bright dash lights, youd have to disconnect the photosensor in the dash, but this will also make the "auto" position on the light switch not work
*edit* i think using the main lights position on the switch makes the dash dim anyway so that kills my idea
hey guys,
thanks everyone
Here is the DIY to headlight adjustment
http://g35driver.com...projectors.html
Don't know if 03 has projector housing? but adjustments should be the same?
Edited by jbenj
On mine, the dash lights don't dim until it gets dark enough, so if you turn on the headlights in the middle of the day, the dash lights stay at full brightness.
Short answer --- NO!!!
The factory ballast on these cars are 35W, if you want to go to 55W you will need to change the ballast as well.
i was assuming 55w was just his typing error, as all ive ever seen in hid is 35w
do they even make a 55w hid?
as for the auto dimming, just checked on my 2001 sedan, DISCONNECTING the photoeye on the dash WILL stop it going dim
Yeah i've got the same problem with the dash lights mate they go dim once it hits dark, it's a good thing though because you quickly adapt to the brightness whereas if it was blearing at you all night you would get tired a lot quicker.
just saw my typo... it was meant to say:
disconnecting the photoeye WILL NOT stop the dash lights going dim
the system is set to run in dim mode UNLESS there is enough light to operate the the light sensitive switch, which then makes the dash illuminate at full power.... so unplugging the sensor will make the car think it is night all the time
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
