hey guys,
While I love my V35 she's got some sore points that i've just dealt with, but wanted to know if others had the same issue.
Basically I find the headlights in it arent strong enough..
HID yes, thats great, but driving i get what seems like only 6-10m of visibilty out of them if the road is pitch black..
I can jump in my partners mitsub mirage and the headlights on that light everything up like its xmas...
anyone else have this issue ??? I just wanna know if its a common thing, (2003 model / 6spd man) or if its just the lights they come with arent that strong?
are we able to upgrade them without causing mass drama?
Also I have no button to increase my dash lights brightness, I know where it is supposed to be, next to the boot release switch..
problem is there is another button there, I will take a photo and post it up, but its a button that has a picture of what looks like windscreen with a squiggle line across it... ???
anyone else have that in their car ? I have no idea what it does when I press it at all... short of pulling the dash apart to trace it :(
thanks everyone
The dash lights are auto.
You can tilt your lights up. There are two "bolts" that you can turn to tilt them up. They are on the back of the lights. Hard to get to but it can be done.
Just wondering, I got 06 coupe, comes with xenon projector/HID if I want to change the bulb to say 6000k 55w can I just buy those HID bulbs say from eBay will it be a straight replacement? Do I need to buy like a separate ballast?
ebay hid kits are generally not interchangeable.
you need to firstly check the bulb type currently fitted (probably D2R) and then order a pair of those in 6000k
but as per usual with ebay - cheaper is cheaper. buy chinese and youll still be squinting
the main thing to work out is why yours are currently poor. its not normal. as said before, get the beam alignment checked. if youre in adelaide i can help
Edited by Deep Dish V35
hey guys,
thanks for the responses, nah I'm in brisbane, thanks for the offer though..
I spent a while tonight going to town on the lights with meguirs plastic cleaner to try see if that would help a bit, they were getting a bit 'grubby', took her for a drive and that seemed to improve it a little bit... not sure if they need to be pointed up much, as driving along road signs light up perfectly fine in the distance, just the light on the ground etc doenst seem "strong"..
I may very well be comparing this to cars like accords etc whose headlights seem to be almost floodlights ..I'd love to compare to some peop in brisbane perhaps, i may very well be expecting more from it than what its gonna give :) hehe
as for the mystery button, I thought it may be a windshield demister button as well, that would explain the button...
I know the dash lights are auto, i'm just picky and would like them brigher when the lights actually come on..
if you want bright dash lights, youd have to disconnect the photosensor in the dash, but this will also make the "auto" position on the light switch not work
*edit* i think using the main lights position on the switch makes the dash dim anyway so that kills my idea
hey guys,
thanks everyone
Here is the DIY to headlight adjustment
http://g35driver.com...projectors.html
Don't know if 03 has projector housing? but adjustments should be the same?
Edited by jbenj
On mine, the dash lights don't dim until it gets dark enough, so if you turn on the headlights in the middle of the day, the dash lights stay at full brightness.
Short answer --- NO!!!
The factory ballast on these cars are 35W, if you want to go to 55W you will need to change the ballast as well.
i was assuming 55w was just his typing error, as all ive ever seen in hid is 35w
do they even make a 55w hid?
as for the auto dimming, just checked on my 2001 sedan, DISCONNECTING the photoeye on the dash WILL stop it going dim
Yeah i've got the same problem with the dash lights mate they go dim once it hits dark, it's a good thing though because you quickly adapt to the brightness whereas if it was blearing at you all night you would get tired a lot quicker.
just saw my typo... it was meant to say:
disconnecting the photoeye WILL NOT stop the dash lights going dim
the system is set to run in dim mode UNLESS there is enough light to operate the the light sensitive switch, which then makes the dash illuminate at full power.... so unplugging the sensor will make the car think it is night all the time
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
