Hey i have just done a AWD NEO RB25Det conversion on my R32 GTS-4.
i have 2 questions.
does anyone know the biggest rotors i can get to fit? as i dont want the pits to send me back after fitting stock size r32 gts4 rotors.
it looks as tho the gts-4 runs the gtr calipers but smaller rotors.
stock 32 gts-4 rotors - Front 290x30
Rear 292x18
stock 32gtr rotors - Front 296x32
Rear 297x18
and what have your experiences been with registering an engine upgrade and then did you need to also upgrade the brakes in size?
i know laws change from state to state but info would be helpful.
thanks.
Are you sure the stock gts4 was 290x30? I thought it was the same as the GTST type-m at 280x30, different calipers as well. I have the GTR calipers with 296x32 discs on mine atm.
Both are 4 pot sumitomo's but definately different calipers.
Upgrade is to fit R32 GT-R rotors and R32 GT-R calipers to the front. The GTS4 caliper is similar to the GT-R, except the "ears" are shorter to accommodate the smaller rotor, and they don't need to be as wide, since the GTS4 only has 30mm thick rotors and GT-R has 32mm rotors. That is why you need to do rotors AND calipers.
I did full hub conversion on mine, But the 32gtr caliper will fit gtst rotors no worries,
If you are getting an engieneer cirt, Then yes, You will need to match the brakes to the engine as if it were stock.
But like i said, Ive called the RTA or what ever you have were your from and its a realy stuff around, and will cost a coupel grand aswell, and need and emmisions test.
The few import mechanics ive spoken to, Told me to just come down and get a blue slip, ANd get a change of details form form rta to change the engine number over.
Sounds right though, Our gts4 also came in a turbo equivelent, You should be more then fine.
Ive put a rb26 in mine, But ive been told this is also fine as you can argue the cars usues the GTR drive train, Have used GTR brakes ect ect.
see how we go anyways :/
R33 and R32 gtst brakes are quite different. R32 is 280x30. R33 is 296x30. I wouldn't be suggesting to anyone to use r32gtst rotors with r32 gtr calipers.. :wacko:
Personal preference given my experience on my car, I'd go r33/r34 brembos. 324mm discs.
I don't think anyone above recommended 32GTR calipers on 32GTSt rotors.
The fact is, the minimum legal brake swap to put an RB25 into an R32 is the R33 brakes. Next small step up is GTR. Then step up to R32/33 Brembos. I would suspect that the R34 Brembos have the same bolt size issue that the normal R34 brakes have (ie, they're bigger diameter caliper bolts than the earlier cars) which makes fitting them harder (have to drill out the mounting points on the hubs). So I'd not go to R34 brakes before looking at other alternatives.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
