Iv only got the car yesterday and it is getting better the more I drive it. The car has been sitting for a while.
Could be plugs then. My plugs fouled so bad that the car wouldn't even start. That said, my car had an underlying issue (coilpacks).
Change the plugs.
Changed the fluids and filters.
The fuel filter was so clogged I couldn't even blow threw it.
Its getting better when go to accelerate and it's smooth but it's feeling like a traction control is on.
Engine is keen to go to 7000rpm but in the wet today it felt like traction was on.
Is that sounding like a diff problem?
Plugs changed tommorrow and so will coilpacks, that should sort misfire problems.
Okay I will take a video tommorrow, it's not popping it's jerking.
I just took it for a drive and it seems as soon as the tyres are losing traction it feels like your driving over light pot holes.
Car seems to wanna stall at low rev when once put in gear.
If its been sitting around for a while its possible for the fuel to have gone a bit stale and cause a few running problems, you may just need to fill it up with fresh tank of premium
Car is still jerking replaced the spark, checked the coilpacks for cracks. My oil pressure gauge sits on almost no pressure when I'm driving at about 100ks?
I'll be replacing the fuel pump next week to see if that done it?
It's making a poping noise (popcorn in the microwave)
Its happening from 4000rpm it starts. I have a video of it now but it's not very good. In the video it makes the poping noise in 2nd gear if you can hear it
Also gotta add it wants to stall when I take it out of gear, it drops to almost 0rpm then jumps back to 650rpm. It's not hunting for and idle only.
Wants to stall when Taken out of a gear to stop. Only sometimes.
I'll change coilpacks and spark.
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
