Okay I came back because I feel bad...
Bike sounds like a good idea.
Do what I am currently doing and for lunch cook up some chicken + broc
If you prep your meals it will help you A LOT!
Keeps you on track.
The days I dont prep I find myself going ehh may as well just get this.
and look down and I am eating some fat burger
My biggest problem...
Dont like any vegetables.
Salads, sort of ok, but not veg.
Closest i get to veges, are hot chips, because theyre potato.
Used to be the same on the vegetable subject.
Then I became a man.
It's no longer an issue.
This. Have had brocolli/cauliflower boiled for dinner maybe 3-4x a week for the past couple of years, minus 3ish months (binge).
Do it, after a while you'll get used to it... :yes:
im competitive and like numbers so install 'runkeeper' and use it to improve your walk/run/ride.
Disclaimer: the furthest ive gotten is installing the app :)
thanks.
is that for iphail, android, or both?
I had an app called noom that wasn't too bad, might have to get it back
  • 3 weeks later...
Ok, back in the band wagon, exercise wise.
still eating crap.
went for a 2k walk yesterday arvo.
today was a 1.6k walk, the 30mins on the cross trainer.
feeling pretty good.
cracked the 1.5l mark of water intake, considering I normally only drink soft drink, this is quite an achievement for me.
  • 4 months later...
  • 4 weeks later...
    • I’m hosting a bunch of execs in the McLaren box on Saturday. If you’re around I’ll come say hi, and see if I can sneak out some freebies.
    • Yes. All of this. But even when you get the NOx as low as you can go on an RB, it will no doubt still be way too high. Same with CO and HCs. The tech and the tuning time just isn't there.
    • Dang. I love the little 'oil used' bingo card on the side.   🤣  Well, now they can use a box and an oil-filled goon.
    • Many many moons ago, I was chatting with Andy Wyatt, about his auto ignition tuning. One of the HUGE things he said to me, when tuning for power, right where you hit peak ignition timing for your max torque, dramatically increases NOx emissions. He was finding in testing, particularly on engines you could advance timing beyond peak torque, that backing the ignition timing off a couple of degrees only made for a small drop in torque (compared to if you keep backing it off further the same amount of degrees) but dramatically reduced NOx emissions. I'd say targetting for 14.7, and he's even mentioned in some scenarios going slightly leaner, and pulling a few degrees of IGN timing will help pass for emissions quite a lot. However, who tunes an RB for emissions
    • The main stuff from.Vibrant I see is more their intercooler piping, and everyone raving about their clamps, but when I looked it was about $150 per clamp... I was a bit   I also thought the public price SP had up was high. As Mark said, a normal exhaust shop can fab them. It was many years ago that I had a full exhaust built, but for a full turbo back exhaust, and 2 custom built mufflers, plus a high flow cat, was about $1,100, and that was fully installed, drive in, drive out. I believe SP was about $900 for 2 mufflers, just supplied   These days, I just buy the material and built it myself, because I need to stretch my $$$
