  On 31/07/2012 at 7:55 AM, scotty nm35 said:
But you can only have one or the other, the emanage communication or the sensor adapter I am fairly sure.
Just remember the Greddy sensors aren't cheap but they are accurate. I guess it's similar to buying a Defi set, just more compact.
So can the Informeter display boost via connecting to the Emanage?
if it can I'll get the Informeter...
I guess so, do you have the map sensor on the emu? I haven't used the communication cable for the informeter as it was connected to the Vmanage, perhaps that is why, not the external sensor harness.
Yeah I've got the MAP sensor running to the EMU...don't tell me because I'm using the MAP sensor I can't connect the informeter to the EMU...garrrrh...
Hang on - the Greddy boost sensor for the Informeter looks identical to the MAP sensor I'm using for EMU...
yay?
Edited by ironpaw
yay?
Duuuurrrr thaz cuz itz tha saim sensa
Lol we've had this conversation before Jethro hahaha
  On 30/07/2012 at 1:16 AM, Deep Dish V35 said:
ironpaw.... the picture in the first link shows the ignition barrel on the left - when it should be on the right.... so im assuming the picture is upside down, making the gauges mount from underneath?
Have another look at the steering wheel surround on your car, the ignition barrel location is part of the instrument cluster surround. The only cut-outs on the column cover are for headlight and wiper stalks.
  On 01/08/2012 at 12:08 AM, ironpaw said:
Which gauge did you get?
Don't tell me those fake Defi ones on ebay/forums for $60? hehe
Not a fake Defi, no.
It's called an Evo something or other... It's digital with a line of bars that go along the surround instead of a needle and digital numbers in the centre which make it pretty easy to read with a split second glance.
A bit flashy, but the price was right & I thought if give it a go.
@pv35gt8
hmm, looking at this pic:
http://www.maperform...oupe-03-04.html
It seems like its just the top part of the steering wheel surround?
Take a look at the 2nd pic below...see what I mean? Its just a replace panel really. Doesn't involve the dash or igni barrel at all.
http://www.skylinesa...__fromsearch__1
Only issue is that its black...hmmm
Edited by ironpaw
  On 01/08/2012 at 4:13 AM, ironpaw said:
haha...well if I can score a whole dash in black then I'll go black...
I don't want a beige dash with a single black panel...
or you can just paint it in a colour as close as possible to it.
  On 01/08/2012 at 4:17 AM, iamhe77 said:
Sounds like a proposition?
you want in dont you
  On 01/08/2012 at 3:28 AM, ironpaw said:
@pv35gt8
That is the point I was trying to get across, solution could be as Aaron said paint it as close as you can or replace all trim around the binnacle to black to match.
Personally I would be looking at the painting solution as I don't think you want to replace the wheel as well.
I had found that gauge holder a while ago but at that time had no reason for the extra gauges, hence I did not purchase.
  • 3 weeks later...
Ha, Greddy got back to me regarding getting the MAP reading/Values from the emanage:
"If you have electrical craftsmanship it can be done but for our liability purpose, you will need to run independent sensors to each unit."
Hmmmmm is it as simple as splicing the informeter harness into the existing MAP sensor? interesting..
Edited by ironpaw
No, the input resistance of the unit will affect the value seen making it inaccurate. Just buy the new sensor if you want an accurate gauge.
They are probably talking about making a circuit to feed a mirror signal.
  • 3 years later...
