the fact that it's made in 1995 is pretty much the key factor here. the majority of 95 model r33's are series 1.5 (not an official series though. they are technically just a series 1, but they run a mix of s1 and s2 parts and that's why we refer to them as series 1.5).
Ill try and get to my coil packs today.
Im hoping to find out for info on what parts are s1 and what parts a s2?
Do I buy a s1 front bumper or a s2? If I could get a list happening that would be sweet as.
search. it has been covered many times.
as for the front bar, given that the S2 would probably look much different to yours, wouldn't it be obvious that yours needs a series 1?
most body parts are S1 (other wing). interior is S1 (although there are some differences). coil packs are S2, as is AFM and TPS. that pretty much covers most of it.
not really. you can tell whether it has s1 or s2 coils just by opening the bonnet. you don't even need to remove the coil valley cover.
if your engine has this at the back of the cover, near the firewall, then it is an s1 motor
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
