hey guys
i am buying a cusco 1 way lsd for my r200 open diff
problem i have run into is the lsd for a HR31 and R30 long nose
are listed as different part number by cusco
hr31 is LSD 162 f
and r30 models are LSD 161 f
i have looked every were and no one can tell me what the difference is
i have brought my R200 from a HR31 from what the seller said
and it was an open diff which i know some came out with in the lower spec ones.
the only thing i have been told is that HR31 the crown wheel bolts are 12mm
and r30 are 10mm is this right
thanks
https://www.sau.com.au/forums/topic/405895-cusco-lsd-help-needed/
I believe then only differences between any of them are the crownwheel bolt sizes, which can be easily rectified with sleeves, and the position of the half shaft circlips.
My best guess would be that the circlip positions would be the same between those 2 models, so the crownwheel bolt sizes would be the only difference I would think. This can be sleeved easily enough.
dr30 r200 crown wheel bolts are definatly not 10mm. they are 14mm.
im not sure on differences but my mates hr31 has same diff as my dr.
both styles of cvs are interchangeable.
wouldnt bother with a cusco 1 way any way, just add more clutch packs
i am getting one though a mate from japan cheap brand new
my diff started life as an open long nose i though the bolt size was the only difference thanks for the help
i don't want 2 way its just a weekender
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
