hi wreaking a r33 gtst seris 1 white 105kms wreaking whole car. let me know what ur after and i willl get back to with a price. i will state d main things i have are as follows
gearbox great condition $1200
m sports full biodykit $500 brank new still in plastic
cusco bolt in full roll cage $600
sard 550cc injectors $600 second hand in fuel rail
racing seats with rails $200 bride knockoffs
tein ha coilovers $500 second hand in good condition
hi mount set up made 290kw at d wheels turbo manifold external gate
boost gauge autometer 20psi $70
full 3 inch exhaust
front pipe
airfuel, volts, oil pressure gauge autometer smaller gauges
gready turbo timer
monster taco brand new
starter motor
alternator
powerstering pump
diff
doors
windows
pm or message or call or message me on 0411750985 if u have any questions
im in sydney (west)
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
