hi guys been having a problem with my rb25 in my r32 for about a week. just started all of a sudded
it has a blow off valve that i think is plumbed back and not atmospheric venting. i dont believe it is the blow off valve stalling issue thats very common with atmo blow off valves. had that on my r33 and this isnt same.
what is does is sometimes it idles at normal speed around 1000rpm or so. sometimes it will rev up and down 200rpm from about 800-1000rpm. sometimes if i sit in neutral it will idle good then change into the fluctuating idle thing.
its really getting on my goat so need yas to tell me whats wrong.
thanks guys
https://www.sau.com.au/forums/topic/405934-idle-moving-around-rb25det/
Getting on your goat haha!
-clean your AFM (electric contact cleaner)
-clean your AAC valve (Carby cleaner)
Walk through for the AAC in the tutorial section.
AFM you should be able to do yourself
Then report back.
Also make sure that it's not ATMO it's as simple as popping the bonnet don't just guess it is
il do those things.
the reason i think its a plumb back is that it doesnt have a trumpet and cant see a venting bit on it. and seems to have a pipe that looks like it goes back to somewhere. have studied it wen i got the car and came to the conclusion it must be a plumb back but will look again
Yeah just follow it and be positive it heads back towards the intake.
Could be venting somewhere down the side to hide from police or something stupid like that.
I found it for you just incase.
http://www.skylinesaustralia.com/forums/topic/110431-diy-aac-valve-cleaning-idle-reset/
  • 3 weeks later...
i got out of it easy luckily. looked at motor for abit before i went any further. spotted a broken vacuum line from plenum to cant remember. replaced that and problem fixed.
thanks for the suggestions but. probably would have left it for ages if i had to do that aac thing. alot nicer now but
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
