For sale is my pride and joy I have put countless dollars and hours into.
This one of a kind S15 was purchased bog stock 15 months ago. The car has just ticked over 100,000kms (photo of odometer taken as at 1/7/12) and she has been serviced religiously every 5,000km and only ever run on BP Ultimate.
Reason for the sale is I currently have 2 cars, and need to sell one to purchase property at the end of the year.
Mod list as follows, most items fitted within the last 7 months.
Power/under the bonnet
Brian Crower stage 2 264/264 cams + valve springs + retainers
GT2871r .86 housing turbo + braided lines
Z32 AFM
Nistune ECU
Nismo 740cc injectors
Walbro 255 fuel pump
Custom metal intake pipe + Apexi Power intake pod
Blitz LM FMIC
Koyo Radiator + hose kit + nismo high pressure cap
Greddy Profec Bspec II ebc
Apexi N1 Titanium exhaust
Exedy HD clutch
Handling & Brakes
Nismo R-Tune springs and shocks
Whiteline Adjustable front swaybar
Selby rear sway bar
Nismo Power Brace
GKtech Subframe collars
GKtech adjustable castor, camber, traction + toe arms
Whiteline front camber bolts
R32 GTR front brakes (callipers + rotors)
HEL braided brake lines
EBC Yellow Stuff Pads F+R
Nismo Front Strut Bar
Exterior
Full M-Sport body kit
Seibon vented Carbon Fibre bonnet
Carbon Fibre boot
Smoked LED taillights
Nismo tinted side indicators
Interior
Autometer Cobalt boost/vac gauger
Wheels JC Project BR6 19x9.5 +22 19x10.5 +22
Please no swaps or lowballers. Must be cash sale only
Feel free to make an (reasonable) offer. Worst I can say is no.
Car is located in Green Valley and I am contactable on 0431 083 394 for any questions or queries.
Asking price is $22,000. I believe this is a fair price considering the amount of money spent on the car.
Cheers guys,
John
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
