  • Replies 90
  • 4 weeks later...
Bump
Weathershields sold
One lhs gaurd sold, one remaining
Rhs lca sold
Rhs tie rod sold
Strut brace sold
Still a few bits here-keen to move them on...
  • 3 weeks later...
Hey mate have the rear shock mounts-have them as one piece with hub and lower suspension arm.was after 80$ each side but if need be I can separate- them.might be easier for you if I sold to you as one piece rather than pull all yours apart?yes forked type.
No exhaust sorry
No gt Ecu sorry
Bonnet sold
Both lhs gaurds sold
Gtr bumper gone
Still got bits here- diff,subframe,steering rack, doors, coil overs, etc. will update list soon when I can be bothered..,
Hey bud was wondering of you had those two brakets (one on each side) which hold the bumper to the fender?
Cheers
Sorry mate I don't.
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
