hi guys
i just spent about 3350$ on my car
got a fully stock R33 engine , harness and ecu with labour.
now everything is okay except the power steering and speedo
Power steering looks like doesn't work. I checked the fluids and all, everything is topped up but still that doesn't work .
what it could be? before engine replacement it was all good
Edited by Burrieddreamz
  • 4 weeks later...
okay so now Speedo is working and Power steering is still the same !
can it be a pump ? cuz one of my mate said it could be
am now running Series 1 engine and series 1 looms not series II !!
what can be the other issues?
I don't know how to find that out.
I know this thing that Series I doesnt have HICAS but Series II has.
now with my car ive recently installed Series I looms, ECU and S1 engine ( S2 harness have been pulled out)
so does that mean its not connected?
I heard if HICAS Is a issue it gets heavier . whats the possible solution you can think of? needs a Series I power steering parts?
Speed sensing steering ? low speed light , high speed tight
Does the pump whine ?
Air pockets or leak?
Enough air in the tires ?
Is the fluid foamy ? Or not red ?
Dump oil replace with "lucas power steering oil " from stupidcheap 20 bucks and your steering will love you it makes it so much smoother and no more whine on the pump unless its shagged or full of air ( leaking )
Jack up the front wheels and turn lock to lock a few times to rid rid the air pockets and work the new oil in
