Same as Sean, sometimes peaks at over 2000rpm on cold mornings, but only for a second, then quickly drops back to about 1500rpm, then drops slowly until the engine is warm, then sits on 600.
https://www.sau.com.au/forums/topic/405987-revs-at-startup/#findComment-6467569
One thing i have noticed though when i park my car over night outside and i drive in the morning, the engine sounds a lot better cold than warm (normal) but it feels a little bit gutless until it's warm but that just may be because i have it overnight 12 hours or so in 10ish degree cold.
https://www.sau.com.au/forums/topic/405987-revs-at-startup/#findComment-6467632
you might need an oil change? how long until your next?
or one of your O2 sensors might be faulty/dirty.
or it's really cold
Flushed and changed my oil last weekend, o2 sensors are fine checked those a few weeks ago too.
He's in Mackay... It doesn't get cold.
Not true man! 2 weeks ago it hit 4 degrees here at night/morning
https://www.sau.com.au/forums/topic/405987-revs-at-startup/#findComment-6467930
not sure why it does it.. the VQ35 in other cars doesn't rev that high.. but it does seem normal for the V35.
My Stagea revs to about 2400 for a second from first start in the morning and then drops as it warms up. Always has.
Damn thing won't drop below 750 when warm...
https://www.sau.com.au/forums/topic/405987-revs-at-startup/#findComment-6468121
have you done the idle air volume learn procedure?
After cleaning my throttle body, it wouldn't idle much below 900 until I ran this process.
I guess the VQ35 in the Stagea is probably setup the same. The VQ35 in the Murano and Maxima don't rev anywhere near as high at cold startup.. not sure why our cars need to?? I know they are tuned differently, but I am not sure why that would make a difference.
https://www.sau.com.au/forums/topic/405987-revs-at-startup/#findComment-6468173
i remember my startup revs situation started happening after installing the 350z intake tube. did both the throttle learn and idle air volume procedures multiple times with no improvement. there are absolutely no leaks anywhere.
its something i want to fix before installing the plenum spacer.
https://www.sau.com.au/forums/topic/405987-revs-at-startup/#findComment-6468331
I did indeed. Prior to the relearn, it liked idling at 950rpm when warm.
Far cry from my old VQ25det Stagea that idled at 550 when warm.
https://www.sau.com.au/forums/topic/405987-revs-at-startup/#findComment-6468430
I have a cable (+ laptop) & can set the idle to whatever I like (within reason). I should send it down to you one day; if no one in Melbourne has one you can borrow.
Edited by Commsman
https://www.sau.com.au/forums/topic/405987-revs-at-startup/#findComment-6468491
I'm far from an expert on any of this but is it possible that the vq35 in our cars reacts differently than other models due to being released for the Japanese market? It gets extremely cold there so maybe it is required for that climate??
https://www.sau.com.au/forums/topic/405987-revs-at-startup/#findComment-6468540
Usually, and don't quote me on this :D they will rev higher on startup to heat up cat coverters quicker for emissions reasons.
A mate's 350ZHR did the same thing.
I would say this probably isn't the reason, the revs only peak to 2000rpm for a second then drop back to about 1500rpm, which is where most cars idle when cold. If the intention was to heat the cats and O2 sensors, it would need to stay at high rpm for much longer.
https://www.sau.com.au/forums/topic/405987-revs-at-startup/#findComment-6468684
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
