I agree when i first played SOF2 i was all like "meh!"
But now im all like "yeah!"
The tip is!
When starting a new game choose custom difficulty.
Then set the amount of saves to unlimited.
Makes it a lot better. Limited saves is cr ap and too hard.
I am playing it on the 2nd difficulty with unlimited saves. Its fun. Especially later on. The first few levels are boring but once you get into it its much more action packed.
Bah why bother downloading games. Unless you want to save $5.
Guys at my work hire them out from a local cd hire store for $5 and burn them. Much quicker than downloading.
A few games they have downloaded, but only because it was before local release. IE... I got Jedi Knight II and Freedom Force a week before release in Aus :P
*DISCLAIMER*
Pirating games is bad mmmkay......
  • 4 weeks later...
    • I thought you didn't let mechanics, especially those with no idea, work on your car any more? Wouldn't that mean it won't be an issue in your case?
    • Is it possible to get them dilled and taped if its not there. Same for oil feed and turbo drain, is it easy to get them taped or i should get the supply from somewhere else?
    • I'm not doubting it does something, there's clearly a reason why Nissan bothered with it on the transmission/diff/transfer case but it's more just the effort of finding a drain plug that isn't going to have some unexpected design problem that makes me lazy. For example even the Nismo branded ones here spec way less than the factory 20 N-m. They say only torque to 10 N-m. That is getting absolutely trashed the moment you take it to any mechanic who isn't familiar with the specific requirements and assumes it should be torqued to factory spec.
    • Same same. DE block has no oil squirters though. You either live without them, or go to the effort of adding them. The type of pain is up to you.
    • Thanks for bringing this workshop to my attention, i didnt know about it before and Jessie did some Fabolous work on my car! Helps that its close to home as well, hate having to drive half way across melbourne for a decent workshop.  https://www.instagram.com/p/DIPwaQ1yHMe/?utm_source=ig_web_copy_link&igsh=MzRlODBiNWFlZA==
