7. No external links! - Do not post likes to items being sold on e-bay, or other forums. If you wish to start a thread advertising the same items on SAU, you must include all details and price in your thread. Asking people to refer to e-bay for more info is not acceptable. If you're too lazy to copy and paste the details on here, your thread will be deleted.
lol..... who made you a mod Mat.....
Anyway, 500hp atw with 550cc injectors...I call BS :yes:
Just doin my duty :yes:
And it's eq to a T88 it says.... :P 500hp at the spare tyre!!
Edit - and it was copy and paste from the rules cus I am lazy :D
Guest
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
