Hey guys, I've searched here, google and eBay looking for the black pipe/hose going from one cam cover to the other on an R34 RB25det. Happy to buy even a universal silicon hose piece but seem to find that either. Guess I'll try a bit harder but in the mean time does anyone have a source for these? Would heater hose be ok for now? (mines gone rockhard and split really bad)
Any hose store?? Theoretically heater hose 'should' be ok, as it's mostly air with just a bit of vapour. But really you should get some proper oil control hose. I get mine from Hoseco. Otherwise Enzed, Pirtek, etc. etc.
Just go in and ask for 5/8 oil control hose.
heater hose wont work as the vapours going out of the rocker covers are hot and the hose will crap itself, as the hose is shaped your best bet is to get one from nissan,or you COULD get one from hoseco but you may have to buy a metre of it unless they have some leftover off cuts
Heater hose will work as a temporary solution is what I meant.
You don't need to use the formed hose, you can rotate the breather to suit any hose. No point paying out the ass for pre-shaped hose. You can also buy half meters from Hoseco. At $18 a meter it's not too bad.
Edited by Hanaldo
So is Siicon hose suitable for this? I can get the piece i need from Nizzbits for $35 delivered so I can use silicon and get it for 18 a meter like u said. Although I do like fitting genuine parts where I can.
go the genuine part if you can, the hose you can get from hoseco may or may not posses the heat resistance that you need. . .as a GUIDE i paid $18 for a breather (from rocker cover to rocker cover) hose for a R32 RB20DET from NISSAN. . .yes you can use heater hose as a very temp repair but why not fix it properly the first time?
It says it's for a RB20DET but those cam breather hoses look the same to me as RB25DET's as well (confirm the part # to be sure). http://www.kudosmotorsports.com/catalog/nissan-hose-blowby-genuine-nissan-skyline-r32-gtst-rb20det-p-581.html
whats wrong with heater hose? ive had it on my 34 for about 4 months now since i noticed the old one had split and i cant say ive seen any ill affects at all, ive taken it on and off half a dozen times since then as well, never had any troubles or noticed any wear or anything.
    • I'm interested if anyone agrees with what you've said, and can give a good reason. Temperature of powder coating should be below any temperature you'd use to alter the wheel structure.  Powder coat typically 200 to 250. Annealing if that's what people are claiming would be occuring, starts at 300, and depending on the alloy, can need even up at 400+.   That's the only part I can think of that could cause an issue that people are believing it's from the rim losing hardness and becoming too soft.
    • Negative probe should be on the cars chassis. Positive on the wire.   Start as said above by unplugging everything (unplug the lights, and switches. Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch. If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.   Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.
    • Anyone know if it's a problem to powder coat forged alloy wheel centers (Rays/Volk GT-C). some say it's bad and can damage the alloy, some say it's not a problem.
    • Hey guys, I'm reviving an old post but I'm finally getting around to working on this now. I removed the battery to get a better look at the wires and i traced the wires from the headlight to the fuse box in the engine bay, but the wiring looks fine? The wiring for the R/H headlight is 3 wires and then is bundled up with the large diameter wire that goes underneath the fuse box. I didn't take it apart yet. I know you said that its a short circuit somewhere between the fuse box and the headlight. But could it be the headlight switch on the dash? Also, i pulled out my multi-meter and set it on the Ohms, but i'm not sure where to put the negative probe and the positive probe.
    • I have a 2 lt in Sydney. It was fitted on a R33 GTR, not used for several years . If you are interested email me on: [email protected] I'm not on this forum much .
