If you are a business new to SAU - Welcome to one of the largest Automotive forums of it's kind in the world.
If you are an existing business, you'd be likely aware of what is about to be said below.
SAU requires all businesses wishing to trade/drum up/advertise their business - to pay a trader fee and get behind the website that you are getting business and exposure from. Our rates are very reasonable compared with other websites around Australia given the amount of traffic you will see.
For more information on the trader options, see here:
http://www.skylinesa...sau-click-here/
For the Fabrication section only, SAU is willing to negotiate pricing structure to your needs. Please contact Blitz or Myself via PM for further information & discussion.
Due to recent events with businesses/individuals circumventing our rules, which overall are not very demanding, the following action is now being taken.
As of today, 01/08/2012, any user we find posting in this section as a business - will have their threads closed.
This includes but is not limited to:
- Pictures of work, with clear user signature advertising and in-picture promotion/signage
- Quoting/Pricing of items in threads
- Drumming up sales via PM's (this includes quoting/pricing/selling).
Admin discretion applies at all times & have various means to police/investigate the above. Only one warning will be given to businesses going against the rules. Second will be account suspension. We previously have never taken issue with users advertising in their signatures in other areas of the forum. However some users are only post in this section and nowhere else. Pretty blatant advertising in our eyes and as is usually the case, it's the few that have ruined it for the majority. We also need to look after those businesses who have stood up and engaged in a trader package.
All threads that currently exist, will remain as they are a good resource even though quite a few contravene the above. If they are updated any further they will be removed.
This action is unfortunate and really is a last resort as this section is generally a good resource. However we've tried to be nice about it and give people friendly "hints" to become a paying traders, and only a select few have bothered to do so.
Thanks.
Admin.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
