  • Replies 54
Posted Images
I just bought the Varrstoen ES111's in 18 x 9.5 +12, which were the wheels in the very first post in this thread.
My wife said I was worse than a woman trying to decide on a pair of shoes!! Hahahaha!!! But true I think.
Hahaha good stuff mate, should look good!
Going to pick up some red anodised wheel nuts too to add a little colour.
Oh and I need to buy some tyres too.
I will take some pics when they are on.
Also have bought an Apexi Power FC and booked the car in with Trojan to do front pipe, catback, install Power FC, boost controller, spark plugs and tune. Couldn't get in until September...Going to be a long wait!! :whistling:
Angie moved on. I'm not one for gossip on particulars unless it affects my car or the service I get.
Anyone a qualified mechanic want to work on skylines full time or does books and has an interest in parts maybe talk to John.
do you have a 10mm socket?
if so, than dont pay money for someone to install the PFC lol
it takes literallty 30 secs
yup I was running 13's in my gtst on the stock/default tune and standard turbo
but I had 8.5:1 comp in that engine, so it was a little safer...wouldnt reccomend flogging the hell out of it unless it was tuned properly
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
