I have a S1 Stagea RS4 auto with the under dash hand brake + release handle, I've just had the rear brake pads replaced and last night I noticed the (!) symbol flickering on & off whilst driving.
Is there a sensor for this light? Or do I just need to find the hand brake cable and apply some grease?
Any thoughts?
https://www.sau.com.au/forums/topic/406053-sticking-hand-brake-light/
actually, it is more likely to be low brake fluid - the handbrake light is also used for that.
Have a look at the fluid level in the large resoviour in the engine bay near the driver's a pillar. If it is low you either have a fluid leak (bad) or your pads and discs are low and ready for replacement
Aren't there two resivours and if so where are they, i know the one near the break booster but someone was talking about one below there or something. I think i have this same problem or at least i hope it's this simple!!!???
sorry I wasn't very clear - the warning light is either handbrake on or low brake fluid, and low brake fluid only happens from a leak or sometimes pads worn.
If you have plenty of fluid in the master cylinder, it must be the handbrake switch not releasing properly.
Thanks Duncan, I'll have a look to see what I can do!?
  • 1 month later...
Has anybody located the switch I'm referring too?
Any thoughts?
The switch should be on the rearward side of the foot brake you use for parking. Its a peg type that extends out ward to form the earth for the circuit when you depress this lever.
Having rear pads replaced wont help your park brake position as the park brake is the internal hub type (Pretty sure). If you have noticed an improvement in your park brake its possible there has been an adjustment made to your cable under the dash rather than at the rear wheels.
Could be the switch has been knocked loose?
Try releasing the park brake then get your toe under the pedal and pull it back a bit.....
I still have the same problem. At first I had to put my foot under the pedal to make it release, then it stuck altogether.
I fixed it by disconnecting it. Maybe one day I will try again and also make the ABS light go OFF.
Which cable seizes? Is it the one from the dash to the splitter, or one of the wheel cables?
Generally, the inner sheath rusts and damages the plastic coating on the cable, which makes it jam. No amount of lube down the sheath will free them up.
I know it's pretty obvious, but if you can work out which cable it is; there are companies that can manufacture factory style, plastic coated inner wire replacement cables.
I'm sure Nissan replacement cables will be fairly pricey.
The rusty cable may be the answer I am looking for. The 25G came from a salty road area in Japan. While repairing the smash damage we found several patches of quite serious rust and had it all cut out and repaired. Soon as it is driveable this week will put it on the hoist and check it out.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
