All partsd are in excellent condition unless stated otherwise.
Genuine ARC catch can/washer bottle combo to suit 33 gtr. Hard to find piece in top condition....350 dollars
Pair of Blitz blowoff valves mounted to gtr pipe (suit 33 and 32) In good working condition....175 dollars
Greddy fule rail with dash fittings and mounting hardware. a couple of small scratches but otherwise great.....200 dollars
Carbon fibre cold air headlight replacement suit 33 gtr/gtst.....75 dollars
2 litre surge tank with some fittings, has never been fitted, as new.....125 dollars
Items are located in ipswich qld. Payment is by cash or postal money order only. It is the the safest way bar none. no bank transfer or paypal.
I will post at buyers expense, I will also be attendiing super lap in sydney next week and can bring parts with me.
I can be contacted via pm or ph. 0413863207
No dreamers or lowballers, I'm not interested.
https://www.sau.com.au/forums/topic/406060-after-market-33-gtr-parts/
u have any papers to go with the greddy ( fuel ) rail? and its for 33 gtr or will fit 34 as well
Its a greddy fuel rail and will fit any RB 25. I have no idea what papers you are referring to.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
