All partsd are in excellent condition unless stated otherwise.
Genuine ARC catch can/washer bottle combo to suit 33 gtr. Hard to find piece in top condition....350 dollars
Pair of Blitz blowoff valves mounted to gtr pipe (suit 33 and 32) In good working condition....175 dollars
Greddy fule rail with dash fittings and mounting hardware. a couple of small scratches but otherwise great.....200 dollars
Carbon fibre cold air headlight replacement suit 33 gtr/gtst.....75 dollars
2 litre surge tank with some fittings, has never been fitted, as new.....125 dollars
Items are located in ipswich qld. Payment is by cash or postal money order only. It is the the safest way bar none. no bank transfer or paypal.
I will post at buyers expense, I will also be attendiing super lap in sydney next week and can bring parts with me.
I can be contacted via pm or ph. 0413863207
No dreamers or lowballers, I'm not interested.
https://www.sau.com.au/forums/topic/406060-after-market-33-gtr-parts/
u have any papers to go with the greddy ( fuel ) rail? and its for 33 gtr or will fit 34 as well
Its a greddy fuel rail and will fit any RB 25. I have no idea what papers you are referring to.
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
