45LDE Posted August 1, 2012 Share Posted August 1, 2012 okay i have a R32 with a RB20DET and before putting it in the shed it was running mint didnt miss a beat. And its been almost 2 years and iv gone to start it and found it very hard to start and when it did i had to hold the throttle on to keep it alive and is coughing and spluttering, high fuel smell from the exhaust. I changed the plugs and drained the fuel and added fresh stuff in and it didnt help. Checked spark all good. so i started to pull the plugs off the coils to work out what cyls are down and i believe at least the first 2 are not going and even maybe the 3rd as well. As there was really no difference with the coil unplugged. have i got clogged injectors? or some thing deeper? They are Sard 550cc, they were installed about 3yrs ago from new. Link to comment https://www.sau.com.au/forums/topic/406065-rb20det-down-cyls-after-sitting-in-the-shed-for-over-a-year/ Share on other sites More sharing options...
Hot33r8723 Posted August 1, 2012 Share Posted August 1, 2012 Dryed up valve stem seals in that cylinders creates loss of Compression aka down a cylinder Link to comment https://www.sau.com.au/forums/topic/406065-rb20det-down-cyls-after-sitting-in-the-shed-for-over-a-year/#findComment-6469318 Share on other sites More sharing options...
Hot33r8723 Posted August 1, 2012 Share Posted August 1, 2012 okay i have a R32 with a RB20DET and before putting it in the shed it was running mint didnt miss a beat. And its been almost 2 years and iv gone to start it and found it very hard to start and when it did i had to hold the throttle on to keep it alive and is coughing and spluttering, high fuel smell from the exhaust. Needs a good flogging most likey be injectors of If Loss Of compression Dryed valve stem seals I changed the plugs and drained the fuel and added fresh stuff in and it didnt help. Checked spark all good. so i started to pull the plugs off the coils to work out what cyls are down and i believe at least the first 2 are not going and even maybe the 3rd as well. As there was really no difference with the coil unplugged. have i got clogged injectors? or some thing deeper? They are Sard 550cc, they were installed about 3yrs ago from new. Link to comment https://www.sau.com.au/forums/topic/406065-rb20det-down-cyls-after-sitting-in-the-shed-for-over-a-year/#findComment-6469321 Share on other sites More sharing options...
zebra Posted August 1, 2012 Share Posted August 1, 2012 Errr no Stem seals have no effect on compression Check for corroded connections to the coils, afm etc If its pumping out black smoke it's spark related Link to comment https://www.sau.com.au/forums/topic/406065-rb20det-down-cyls-after-sitting-in-the-shed-for-over-a-year/#findComment-6469322 Share on other sites More sharing options...
45LDE Posted August 1, 2012 Author Share Posted August 1, 2012 no black smoke, changed AFM with a new one made no difference Link to comment https://www.sau.com.au/forums/topic/406065-rb20det-down-cyls-after-sitting-in-the-shed-for-over-a-year/#findComment-6469325 Share on other sites More sharing options...
45LDE Posted August 1, 2012 Author Share Posted August 1, 2012 all connections look good Link to comment https://www.sau.com.au/forums/topic/406065-rb20det-down-cyls-after-sitting-in-the-shed-for-over-a-year/#findComment-6469326 Share on other sites More sharing options...
Hot33r8723 Posted August 1, 2012 Share Posted August 1, 2012 Run some injector cleaner through it Might be stale fuel of if loss of Compression replace Valve stem seals Link to comment https://www.sau.com.au/forums/topic/406065-rb20det-down-cyls-after-sitting-in-the-shed-for-over-a-year/#findComment-6469327 Share on other sites More sharing options...
Hot33r8723 Posted August 1, 2012 Share Posted August 1, 2012 Stem seals are to block pressure from Leavin the combustion chamber some Times they dry up allowing pressure past valve guides which result in loss of compresion down a Cylinder Link to comment https://www.sau.com.au/forums/topic/406065-rb20det-down-cyls-after-sitting-in-the-shed-for-over-a-year/#findComment-6469335 Share on other sites More sharing options...
zebra Posted August 1, 2012 Share Posted August 1, 2012 No, that's the valves job, the seals stop oil from leaking down from the head into the combustion chamber Link to comment https://www.sau.com.au/forums/topic/406065-rb20det-down-cyls-after-sitting-in-the-shed-for-over-a-year/#findComment-6469337 Share on other sites More sharing options...
45LDE Posted October 21, 2014 Author Share Posted October 21, 2014 Fixed, faulty FPR replaced #winning, fuel was coming out of its vac line into the inlet manifold flooding the engine. Link to comment https://www.sau.com.au/forums/topic/406065-rb20det-down-cyls-after-sitting-in-the-shed-for-over-a-year/#findComment-7412469 Share on other sites More sharing options...
Ben C34 Posted October 21, 2014 Share Posted October 21, 2014 Took a while! Link to comment https://www.sau.com.au/forums/topic/406065-rb20det-down-cyls-after-sitting-in-the-shed-for-over-a-year/#findComment-7412493 Share on other sites More sharing options...
45LDE Posted October 21, 2014 Author Share Posted October 21, 2014 I fixed it some time last year and forgot to put up the fix but it def left me stumped for months! 1 Link to comment https://www.sau.com.au/forums/topic/406065-rb20det-down-cyls-after-sitting-in-the-shed-for-over-a-year/#findComment-7412861 Share on other sites More sharing options...
