Complete 33 Gtst Partout With Quality Mods
That's crazy helpful! i'll be ordering both the poly bushings and the weld in kit. In Belgium the technical inspection can be ever more difficult than TUV, but with oldtimers (30+years old) they allow more so it should be ok I think, i'll check with some friends who work there. regarding the FUCA, RUCA & tension rods, i've been learning alot about all the suspension components for my driftcar, but I should probably invest some time in how they should be set up for a grip car instead of the opposite. 馃槢
didn't need the passcode. just needed to put it on a USB. It did the reset but still goes to a black screen after booting up.... this is the file i used if anyone needed to reset there Mark 7 AUCAR T Style for Q50 Q60 back to factory settings https://u.pcloud.link/publink/show?code=XZKbcQ5ZVKVdSGRFSD7wcTLoYyFE0ydGXBX0
By Dose Pipe Sutututu 路 Posted
You work fast and efficient, all that would have taken me at least 2.5 years LOL -
252mm to the centerline of the bottom mount. BTW the front springs were originally 8kg.
Yes, well.... get the main wire off the back of the alternator and try again?
