Hi there
Thought you guys might like to see this.
Got given this item the other day by a guy who apparently got given it by someone that worked in the factory and had it given to him there, not sure how true this is or the full story so was hoping someone on here could tell me more about the history of this piece and how many would have been given out/made?
It feels quite heavy, possibly bronze I think and is about 5cm in diameter.
Looks like a concept 240k on the front of it.
Thanks,
Matt
Here's the pics of front and back:
https://www.sau.com.au/forums/topic/406104-skyline-coinmomento/
Looks like Dom's charger from fast and the furious.
Never the less, verry verry cool.
I done a couple of quick searches and just got a few jap sites.
Also i think the coin is a remembelia of a guy called Shinichiro Sakurai. He worked for a motor company called Prince Motor company as a chassis engineer, Prince Motor company designed the Zero fighters in WWII. That company merged with Nissan in the mid 1960's. He was dubbed Prince Skline because of his involvement in the 'Prince' range of cars that where released in the mid 60's and played a key roll through the next several Prince cars to be realaesed. Shinichiro Sakurai went on to become president of Autech in 86. He kept working for nissan died at age 81 in 2011.
that's cool if it's all legit.
For some reason the first & second post reminded me of the tv show antiques roadshow, where the owner of an antique gets their item appraised & the appraiser talks about the history of the piece. For that reason I read the second post in my head with a british accent lol
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
