Put this up for myself as I have kind of Plateaued as of late with my progress, need a kick in the pants to keep me going.
As of February 2012 I decided I have had enough of my love handles.
Weighed in at 88kg & would fluctuate between 87-90kg before then.
height: 171cm 5"7
naturally stocky build, was never a skinny kid growing up. always had broad shoulders for my size so it helps hide the fat with loose tshirts, but got to a stage where even that couldn't hide it.
Currently weigh: 76kg so lost 12 kg in 6 months. main difference is stepping up my cardio & ab workouts at the gym + cutting out a lot of junk food meals I would normally eat
I have been hovering around 76-77kg for the last 2 months. I'm not really concerned with my final weight figure, concentrating more on getting rid of the last bits of my love handles & getting back the abs I had when I was a teenager.
I think I've reached the limit of results I can achieve just going to the gym, If I'm going to get my abs back I'll need to work on my diet ie; cut out all the junk food!
Work & life in general keeps me very busy, not always easy to cook at home
https://www.sau.com.au/forums/topic/406112-help-me-maintain-motivation/
haha thanks dude :laugh: I'm trying to find pics of when I had more weight on my midsection as I wanted to do one of those before & after shots, but I shied away from cameras for a reason
gonna aim to break into the 75kg range in 1-2 weeks, just maintain the stuff I'm doing at the gym.
Anyone got tips for core strength & abdominals? too much conflicting advice on the net.
I'm trying to get the lean look not necessarily the large bulging six pack
cheers
Edit: Found some old pics maybe 2 years old when I was pushing 95kg
compared to a pic taken this morning
You needs some muscles, do more body weight exersizes.
And drink more beer.
ABS is for cars to stop the wheels locking up.
Seriously though, Good work mate, Ive gone from 87 and feeling fat and shit to 79 and Im feeling much better.
^ ahaha that's one way to keep me motivated cheers :happy:
I work near a food court so too much temptation, but too lazy to prepare food from home. I'm obviously not a fitness health freak so I try to compromise;
During a week I'll get things like grilled fish with garden salad no dressing, subway 6" sub lean meat no cheese wholegrain bread or a sammich from a cafe.
I still get a red rooter/kfc meal 2-3 times a week which is a bad habit so I'm trying to cut this out, just need to ween myself off it gradually, I gave up smokes cold turk3y but I can't seem to do it for junk food FFS!
It's more of a lifestyle change, but do go stupid on diets or supplements, people end up relying on them to much, just try to limit you carb intake a bit and keeep active and you'll be fine.
^ thanks! I appreciate the kind words
Looking back I can't believe I was lugging that weight around for so long.
My gym recently decided they needed to fill up every bit of floor space with machines & benches. Literally no more decent floor space to do proper ab workouts, Farken!
  • 1 month later...
so close to crackin 74kg
been hovering between high 75kg to mid 76kg range for the last few weeks
I've increased my weights & have noticed I'm bulking up a bit more so I'd probably already be there if I wasn't building up muscle
  • 4 weeks later...
  • 2 months later...
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
